Maybe it´s not only my obsession, but I am interested in activation as many „new“ (it means not yet activated) summits as possible… Maybe I am so vain and want to have my call in the „First activated by…“ column, maybe I want to give a chance to others to work another unique.
There are probably two databasis – one accessible from the Sotawatch menu (without login necessity) and the other, which you can open thru „Database“ and by use name and password.
But one thing I cannot understand – why the callsigns of the first activator are different at the same summit. Have a look to
http://sotawatch.sota.org.uk/summit.php?summit=OK/KR-069
http://www.sotawatch.org/summits.php?summit=OK/KR-069
or
http://sotawatch.sota.org.uk/summit.php?summit=OK/KR-032
http://www.sotawatch.org/summits.php?summit=OK/KR-032
or
http://sotawatch.sota.org.uk/summit.php?summit=OK/KR-034
http://www.sotawatch.org/summits.php?summit=OK/KR-034
or
http://sotawatch.sota.org.uk/summit.php?summit=OK/KR-036
http://www.sotawatch.org/summits.php?summit=OK/KR-036
or
http://sotawatch.sota.org.uk/summit.php?summit=OK/KR-060
http://www.sotawatch.org/summits.php?summit=OK/KR-060
or
http://sotawatch.sota.org.uk/summit.php?summit=OK/KR-072
http://www.sotawatch.org/summits.php?summit=OK/KR-072
Where is the true ?
Is needed to say than in some particular cases neither one database, nor the other shows true. By my point of view there is not the utility comparing the time of the first QSO provided from the particular summit. Maybe it is very exceptional, but one day we met three activators at the same summit in the period of two hours (see OK/KR-069 on May 13th.) It is funny as one dbase shows as the first activator OK1HDU (he was the last one), the other shows OK1ZE. Actually the first QSO was provided by myself – check the logs .
As it is not only one case I am wondering how to solve the problem as the similar situation should happen in the future not even in OK/KR…I guess it´s the time to start checking the „Firsts“ also by the time of the Q´s which couldn´t be so complicated.
Apologize my broken English, please.
73, Vrata OK1KT
