In reply to M1MAJ:
My personal view is that the apparent difference in the rules for chasers & activators is a simple oversight when the rules were originally devised.
As regards the exchange of reports, I simply follow a practice that has been widespread throughout many areas of amateur radio for as long as I can remember. Most areas of amateur radio that involve achievement of goals or objectives, however small, usually have some sort of minimum requirement for a contact to be valid. Many of these are unofficial conventions that have developed over time & whose origins may be shrouded in the mists of time.
An example is the confirmation of reports both ways when working DX. If I was fortunate enough to have a 60 minute ragchew with a ZL station & neither of us gave each other a report that would certainly still be a DX contact in my book, but convention amongst DXer’s would suggest an exchange & confirmation of reports is necessary.
When chasing or activating SOTA I simply follow the conventions already in use before I became involved in SOTA. I personally prefer to follow the DX convention of exchanging reports & also confirming the report I have been given with the other station, which seems to be the normal SOTA practice on phone modes. This certainly meets the requirements of the rules regarding exchange of reports for both activators & chasers. On CW I have found that a RR or RRR confirming accurate reception of a given report seems to be the convention, without the need to send the report received back to the other station.
My view then is that by all means bring the rules for chasers & activators into alignment, but please don’t over-complicate things. The conventions that have been used by SOTA activators & chasers for several years work, & are understood by many non-SOTA stations. To do anything that would change the way we operate would be a bad move in my opinion.
My suggestion for any re-wording of the rules specifically regarding the exchange of reports should be worded to mean the following:
“Ideally, signal reports should exchanged between both chasing & activating stations. It is not a requirement for the receiving station to send the report they received back to the other station as part of the exchange, but it is their responsibility to ensure that they have received their report correctly, for any contact they are intending to enter into the SOTA database.”
That wording in my view covers established conventions for both activators & chasers while hopefully clarifying exactly the “report” part of the exchange.
Feel free to shoot big holes in the above if you wish.
With regard to the original question from Andrew M6ADB, I have worked several non-SOTA stations that met the requirements for a valid activation, & given them their summit reference on occasions too, both while activating & chasing. People didn’t suddenly start going up hills with radios when SOTA was originated, they have been doing it for generations & as long as the station is operating within the rules of SOTA, feel free to claim the S2S or chaser contact.
Mark G0VOF
