Hi everyone,
I’m not able to solve this issue:
editing an article, when I use the simbol apostrophe to indicate minutes in coordinates, and inverted commas to indicate seconds, after clicking update button, the system adds the symbol \ before each… it also happen if I use alt+code to insert those characters…
Any idea about?
Thanks.
In reply to IT9PWM:
Hi, I have put a fix in for this. It should work fine now.
73, Jon
In reply to GM4ZFZ:
unfortunately, now if I add an article, it appears just as ")"
check I/VE313
Thanks for looking into this issue.
Sandro
In reply to IT9PWM:
unfortunately, now if I add an article, it appears just as “)”
Hi Sandro, my apologies. I fixed this in a rush before work yesterday and thought I’d tested it but it seems I only tested the update article code and not the new article code. I had left some debugging code in there.
I have now sorted it (I hope!) albeit in a bit of a rush again.
I’ve tested adding, editing and deleting an article and I think you should find it now working.
73, Jon
In reply to GM4ZFZ:
It seems to work fine…
Thanks
