As luck would have it, VK1 will have three 23cm activators out on the peaks Saturday morning local time (2330 UTC). While Andrew VK1AD on Mt Gingera VK1/AC-002, Andrew VK1DA at Mt Mundoonen VK2/ST-053 and Al VK1RX at Mt Coree VK1/AC-023 are setting up their respective SG-LAB 2.5 watt 23cm transverters, Compton VK2HRX will be some 190 km north on Mt Wanganderry VK2/IL-003 with 18 elements and a 10 watt 23cm Icom rig. Signal paths are looking good for three 23cm S2S contacts
In VK, getting four activators on 23cm at the same time is a great result!
Not to be forgotten, our recent newcomer to SOTA, Bill VK1FWBK will be activating Mt Ginini VK1/AC-008 on 40m CW/SSB and 2m FM. Bill should easily clean up the S2S contacts on 2m FM.
Good luck to all and keep an eye out for Aussie snakes. Play safe!
73 Andrew VK1AD
