Video Sota Ec2ag-Eb2fdt EA2/BI-010..014
Hello
EC2AG
In reply to EC2AG:
Hello Antonio - greetings.
The link does not work for me?
Best wishes
Mike G6TUH
Copy-n-paste the link and remove the final “.” thus → http://youtu.be/RvDSqIksn10
In reply to G6TUH:
HELLO MIKE
Well this be if it works properly, and 3.44 minutes, you can hear your call, working my station antenna then Miracle …
greetings EC2AG
In reply to EC2AG:
Hello Antonio.
Yes - good video and thank you. I think my audio sounds a bit sharp so I will check this. It looks so nice and warm on the summit - I do hope we have some proper summer here in the UK this year!
Best wishes
Mike G6TUH
In reply to EC2AG:
Hola Antonio:
Gracias por este nuevo y bonito video.
Ese dipolo que montaste en la cima ¿es un doble bazooka?
73 de Guru - EA2IF.
SOTA aurrera!
Hello Antonio,
Thank you for this new and nice movie.
That dipole you installed at the summit, was it a double bazooka?
73 de Guru - EA2IF
In reply to EA2IF:
Hola Guru
Gracias por ver el video hay que compartilo,para crear aficion.
Si es una doble bazooka comercial de los amigos CUCO la utilizo para el desafio de 12 metros, rinde tambien en 15,suelo montarla en una caña de 9 metros,aunque este dia me decidi por algo mas pequeño,dada las caracteristicas de la cumbre de EA2/BI-010,imposible montar caña.
Los audios que se escuchan en el video,estaba utilizando antena Miracle multibanda,no la bazooka.
Fue un dia muy bonito y disfrutamos de la naturaleza.
14 km de marcha entre ida y vuelta.
Saludos y GORA SOTA
Hello Guru
Thank you for viewing the video have to Share, to create hobby.
If a double commercial bazooka of CUCO friends use it for the challenge of 12 meters, also rendered in 15 floor mount on a reed of 9 meters, but this day I decided me for something smaller, given the characteristics of the summit EA2/BI-010, impossible to mount reed.
The audio you hear in the video, was using Miracle multiband antenna, not the bazooka.
It was a nice day and enjoy nature.
Running 14 km round trip.
Greetings and SOTA GORA
