Tomorrow morning Australian time (8 Jul around 2200 UTC) I will be updating the backend SSO servers in turn. Being clustered, this should not result in any outage for anyone, but will likely log you out and log you back in.
There is also a slight change in the theming, so do not be surprised if the login page changes.
Had a few issues with this, but got it working. However, this caused an issue with the SOTA API that backends SOTAWatch3, so I have reverted the change for now. I will revisit with Jon overnight and attempt again maybe tomorrow.
After tracing down the issue with the SOTA API, we’re ready to cut this over again, and will start this in the next 30 minutes or so. You shouldn’t see an outage, but you will likely need to re-login.
Ok, this is going to be the same issue as before (there was a client side and a server side problem with the API). I guess I missed the summits page. I’ll work on it later tonight after my daughter’s music lesson. In the meantime, log out
When logged in and I select using the “Search summit” box to find a summit, when its displayed the Stats boxes ie “Total Actns My Actns My Chases” are blank. Doesn’t happen via the Associations search.
Also on SOTAwatch3 in the Reflector section “Pinning” does not work.
