Who ordered rubbish WX for Northern England and Scotland on Sat/Sun? Not looking bonny at all.
I was out today on GM/SS-234 & GM/SS-242 and by 1530Z, 15m had been working well. EA7GV, EA1AER, S52AU, regular chasers of mine were good signals but I managed all the following on 15m CW to inverted7 20m EFHW using KX2 + ATU at 10W
N2AF NY
K8ITU WV
KF9D IL
WB2FUV NY
ND0C MN <<<<<<<<<<<< 6250km QRP to QRP
KQ2RP NJ
I’m still getting used to my TUMD paddle so my sending was worse than normal!
You certainly whet my apetite this morning !!! I was glad to find and work you on both 15 and 18 MHz from my modest home station running 90 watts to an EFHW inverted-7. I was wondering what rig/antenna you were using to make it across the pond. Thanks for the info.
Hopefully band conditions hold for the weekend. Our local weather forecast has improved in recent days to give us likely dry weather here in southern New York. Keep a wet ear out for “s2s s2s”.
Monitoring RBN Client, yesterday for the first time in two weeks, some European portable stations were spotted in North America on the 12- and 10-meter bands as well. The 15-meter band also allowed some DX contacts, whereas on the previous days the best-performing bands had been 20 and 17 meters. Let’s see what happens today and tomorrow after 12:00 UTC.
It reflects what is currently showing to be open (from spots) from your location, on which HF band SSB/CW, etc.
At the moment, it reflects no propagation between NA and EU on any band (the graphic is for 17m, which is the best at the moment it seems). I will take a look tomorrow, at the time that I hope to be on my summit on Saturday, to see which band seems to be performing the best for the DX.
As always, predictions are less than reliable but at least I should be able to choose which band to start up on, on Saturday.
I just heard both sides of an I<>VE3 QSO on SSB and the map looks similar so I think it means green-green is open, and unshaded (e.g. the Atlantic) is in the skip zone.
If you hover over the live map, it has digi, CW and SSB zones.
I read it as there were QSOs within the two areas and not between them as that would then indicated with a bridge - such as is shown between Europe and Iceland and Florida to the northern parts of South America. If you expand the map out further there are green island in the south of India and is SE Asia - I do not believe that there are QSOs going on between all the “islands”.
I also suspect the MUF over the Atlantic was below 18MHz, so communications between EU and NA would not be possible.
Did you go to the website at the time you were hearing the I - VE3 QSO? Comparing with my image that was over an hour earlier would not be relevant.
I’ve just found the documentation, which says:
Use the button to start scrolling through the bands. Bands that are not of interest may be skipped by removing the associated checkbox. Selecting a band number will stop the cycling and switch to that band. Maximum usable frequency (MUF) is the highest frequency that supports communication between two points. On this map, MUF can be considered the maximum used frequency, since the display is based on real time data.
So if the MUF over the Atlantic was at say 13 MHz the 14 and aboveMHz bands are not going to be open.
Shame you didn’t grab the graphic.
There is also a cluster driven version of the map but that comes up with small rings to indicate where stations are on, rather than what communication is possible.
I’ll look tomorrow to see if I get an example with an MUF “bridge” between EU & NA.
Addition - same website - this page is also interesting, pulling several actions together:
Also, this just in …
Let’s hope any CMEs from it get here tomorrow and clear before Saturday afternoon!
yes my example was 17m but the same applies to all bands. It looks, from what you say, that the MUF along the EU-NA path is changing rather quickly. By the map you posted, the path is no longer open.
I wonder how terrestrial temperature affects any of this (probably not at all). We’re down at 1°C at the moment, so I’m expecting frost at least in the morning. It could still be my first activation in the snow this year, on Saturday, the way this is going!
Below are the RBN client results from 13:00 UTC to 18:00 UTC today, monitoring cq cw European /P stations to North America. I couldn’t do the reverse analysis because any station in North America was operating /P.
Just alerted for May Hill G/WB-019. Plenty of space to set up with a NW facing slope, giving the RF a downhill start to the US and allowing me to bask in the warmth of the afternoon sun!
If I manage to find all the clobber I’ll have a 100W at least for a bit, to either a 20M dipole or a 2.5M vertical. Mostly CW. Will try and remember to take a mic!
In the likely event that I can’t find all the clobber, it’ll be 10W into an EFRW.
Dealing with the cold: I would hate to sit inside my bothy bag [Terra Nova Bothy 2] whilst doing a SOTA activation as I don’t like to be inside it whilst sitting on my Helinox Chair-Zero with log book / paddles clipboard on my knees and trying to operate the rig.
However, at 75yo and despite wearing two mid layers, overtrousers, cagoule, alpine hat, etc plus inflatable cushion on the chair, I do get cold sitting there for an hour plus even in light winds with no summit shelter and with low “feels like” temperature. Hot coffee and hi-cal food treats help a bit.
I’m wondering if anyone has successfully used their bothy bag in a ‘tarp cape’ method where you throw the bothy bag over your head and back while leaving the front open or partially draped over your knees, so it acts as a windproof cloak.
BTW: I’ve ruled out using a) my tarp - effective for windy conditions but does nowt for ambient temperate b) my tent - it’s too low for a portable chair and I get uncomfortable trying to operate (esp. with Morse key) either crouching, kneeing or lying down.
The cold I have to deal with is definitely less severe than what you can experience in England at this time of year. Tomorrow, temperatures are expected to be around 6 degrees.
To keep warm, I carry a change of clothes in my backpack to put on once I reach the summit. This consists of a tight-fitting thermal base layer, including a long-sleeved top and thermal trousers. Over that, I wear a heavy sweatshirt and long trousers. As a final layer, I use waterproof overtrousers, which also provide good protection against the wind.
The part of my body that usually gets cold first is my feet. When it’s windy, I sometimes put food freezer bags, such as Cuki Gelo bags, over my socks, or I simply put my feet inside my backpack. A Napapijri parka is also very useful.
Of course, other essential items include a thick wool and acrylic neck warmer, a woollen beanie and ski gloves. I also carry a thermal flask filled with herbal tea sweetened with honey.
During the activity, I schedule a short break every 30 minutes to stretch my legs and move around, because I’ve found that when I’m highly focused, I sometimes lose track of time.
