Hello,
I lost tool-tips on the spot’s webpage ? With all info of the operator and summit… How to recover them ??? I don’t (think…) change anything and I’m on Firefox… Does an update done this ???
Thanks for helping
Tof F5UBH
PS “Nouveau Sujet” don’t work too !!!
There is no problem on my Firefox (19.0.2)
If you are using the ‘NOSCRIPT’ add-on have you allowed SotaWatch scripts ?
Stewart G0LGS
In reply to G0LGS:
Hello Stewart,
It works fine last week and since it doesn’t… No update done no programs ad on !!! Mystery of informatics !!!
But when you choose reflector type “French” them new post “Nouveau sujet”… It doesn’t work too !!!
So is it a “foreign” problem ???
In reply to F5UBH:
Check you have Javascript enabled.
Check you have noscript (if installed) set to allow SOTAwatch scripts
Check you have not installed any other Add-ons to Firefox that are stopping scripts.
It works fine on IE ???
I try to desinstal Firefox and reinstal but I don’t change anothing since last week ??? Arghhhhh…!!!
It works… How ??? It doesn’t works when I restart same without add-on…
I must “reset Firefox”… Same if all it good… Java enable accept all from sotawatch… Etc… So that works now !!!
Thanks Andy and Stewart…
Andy,
Where i can find these Tooltips button.I also see no Tooltips button.
73,Walter
PA0ALW
In reply to PA0ALW:
Maybe tooltips is not the best expression to use… When you have the compressed spots selected if you hover over a spot a popup window appears with the full spot information.
Compressed spots is set from the Edit Account page.
Andy,
Thanks for the information.
I see what you mean and its here no problem with Firefox and IE8 and IE9.
73,Walter
PA0ALW
In reply to PA0ALW:
appears with the full spot information.Compressed spots is set from the Edit Account page.
Euhhhhh I’m not in “Compact” mode I’m in “normal” and I never have complete info with the spot ??? !!! ;-(
But Pop-up works again… !!! SO I’ve have all info by them !!!
Bye
