When I download from the database the CSV file containing all summits, each field uses a comma (,) separator.
But, sometimes, there are also commas in the field “SummitName” such as for EA2/HU-089 = “San MartÃn, Peña de” and many others
It is a problem when we are trying to recover each field in a record.
But I don’t know how we could avoid the problem, unless to use another separator such as a semi colon (;).
And this may change lot of soft in the database…
Another solution is to ask to avoid commas in the field SummitName
It would be much, much better if the names didn’t have embedded commas and we check for that now. Some have still crept in.
I can remember having to modify some code I wrote that processes CSV files to parse the line for embedded commas and changed non-wrapped commas to another character. Messy but not tricky to write.
Hello Alain - in some languages (or special routines) for a “explode”-commmand, “exploding” a csv record, you can define a “delimter”. I am sure your will find a solution for that problem in every programming language via google.
Thanks for your replies
I found another solution without using an “explode” command.
I look for commas in the csv line and search for a comma followed by a number (the first digit of the altitude of the summit).
Now it works, thanks again !
