Hi all,
Let’s go ! see you later
73, Éric
Hi all,
73, Éric
Ok Rob,
Should be ok on 40 M SSB. I will be waiting for you.
73’ Alain
This morning , I think the Sun is playing games, as 40 metres was being pretty tricky, with quite a bit of QRN and serious QSB, but signals on it were readable at times, and I did just catch one TM2IF summit on 40 metres. 20 metres to the same summit was much better, still with QSB, but so much clearer. Thanks.
(Over the last couple of months the WRC-15 section of 60 metres has had hideous continuous QRM here which has made that band almost useless for contacts into Europe.)
Good to work you today on F/CR-245
Cheers
John
m0vaz
Hi John,
Tks for the QSO (the only one 20m SSB) you had nice 59 from your mobile setup
But generally the propa was very bad !
73, Éric
Hi all,
From F/CR-245 TM2IF today you can check my log here (SOTLAS)
3 mistakes, please correct your input.
@SM4CJM at 09:06 was F/CR-216
@HB9AGH at 09:07 was F/CR-216
@DL6FBK at 10:41 was F/CR-245
73, Éric
F5JKK
Hello SOTA Friends.
You can check my log here: TM2IF & F5LKW/P on F/CR-216 - 28/04/2022
Thanks for the S2S Roger. It was good to have a QSO in memory of Guru.
73 Richard
Hi all,
today and active now TM2IF
F/PO-162 Op Alain @F5ODQ and later F/PO-175
F/CR-229 Op Roger @F5LKW
Later F/AM-825 Op Gérald @F6HBI
GL & 73 Éric
Thanks Eric. I was mobile with FT-857 and a Am-Pro mobile HF antenna
Cheers
John
m0vaz
Hello SOTA Friends.
You can check my log with TM2IF (F5LKW Roger) on F/CR-229 - 29/04/2022
73 QRO & Thanks for all fun
Roger
HI,
This week there were two days of activation in TM2IF.
The results are very positive with 372 contacts on the different modes and frequencies.
What makes an accumulation over 4 activations days of
1066 contacts.
I tried yesterday in SSB all bands from 40 M to 10 M
On 7, 14, 18, 21, 24 and 28 Mhz and on all bands I made good contacts such as @D44PM (Cape Verde) on 15 M.
Thank 's to all of you chasers, and of course to our activators in the field @F6HBI Gérald, @F6IPR Fred, @F5JKK Eric, @F5LKW Roger and his Sherpa Dog Nioky
Next TM2IF activation on Friday May 13
See you soon on the air
Photos of the PO-162 Summit activated yesteday.
73’ F5ODQ
Hi all,
Let me introduce you to my sherpa dog Louna, she was with me for TM2IF Guru in Memoriam on F/CR-245 the 28/04/2022
73, Éric
F5JKK
Thank you for the s2s contact.
I use examples such as this to demonstrate to newcomers to amateur radio that you don’t need kW and massive antennas to achieve DX contacts, as your 10W and simple wire antennas often prove.
Thanks to you Alain and your fellow activators for this memorial to Guru.
Col VK3GTV
Hi all,
Today, 13/05/2022, you can find TM2IF Guru in Memoriam on :
and tomorrow 14/05/2022 :
73, Éric
F5JKK
Thank you for the 60m CW QSO today from FL/VL-036. My first QSO on 60m! The signal from Christian was a genuine 599 but my QTH was near Limoges so not too far away.
73, F/M0WIV
