TM15SOTA TM1SOTA TM2SOTA (Part 1)
We did it…!
73 from Gerald F6HBI
I have you in my log 14.061 @12:28 (op Gerald from F/AM-396)
My log: TM15SOTA (Op: Roger) - F/CR-209 - 15/04/2022 - 111QSO
Take care, 50 QSO more will be updated for this summit with Fabienne’s log (F4JAI) - TM15SOTA
TM15SOTA Activities on 15/04/2022.
Please CHASERS listen SOTA REF while QSO.
On the same day, same time, same band but different mode you can work several summits with the same call: TM15SOTA
  • FL/VL-070 (by F5HTR) at 06:00z on 7 Mhz
  • F/CR-209 (by F4JAI - SSB & F5LKW - CW) at 07:00z on 5-7-10-14 Mhz
  • F/AM-396 (by F4JCF - SSB & F6HBI - CW) at 09:30z on all bands
  • FL/NO-042 (by F6ENO - CW) at 13:00z on 7-14 Mhz
Please, listen and listen the right reference.
73 QRO and let’s go to funny crazy day !
Can I suggest you add “NoRBNHole” to your alerts if you don’t want RBN spotting? Easier than dealing with the chaser chaos
I didnt know that, i’ll try today.
Thanks
This! Or even filter the callsign at RBNhole - that would be even easier on heavy duty TM15SOTA traffic since no one has to remember this exception.
73, Markus (experienced from other special callsigns hi)
Another simple way of enlightening the chasers would be typing the activator call sign in comments box of either alert or spot.
This would be very much appreciated by at least this chaser.
73 de OZ6ABZ Jens
@S57ILF @DL6GCA @F4WBN @G4OBK @SV2HJW —> PSE correct your log - You did QSO with FL/VL-070 summit
Thanks to the OPs of @TM15SOTA for the s2s QSO today :slight_smile: And of course to you Eric @F5JKK for the QSO :+1: See you next time.
73 Marcel DM3FAM
Mistake: ON
Award will be also available for SWL
Mistake: OFF
Hi all,
Today 17/04/2022 TM15SOTA on :
  • F/CR-229
  • F/AM-617
GL & 73 Éric
F5JKK
Edit :
and a surprise F/AM-385 :crazy_face:
Thanks info Roger - database corrected - Trois more points - fine business!
73 Phil G4OBK
Hi all,
Today 18/04/2022 TM15SOTA on :
  • FL/VL-052
  • FL/VL-049
  • F/AM-207
  • F/AM-346
    and maybe another F/AM-XXX
GL & 73 Éric
F5JKK
Edit : The F/AM-XXX will be the F/AM-651 by Gérald @F6HBI (lsn for ref)
Hello Eric, I double-checked my QCXmini 40m I used during my last TM15SOTA activation, I have 46dB of attenuation between the working frequency and the first harmonic (20m) which is the specs of the TX. I think that I was wrongly spotted by F4VSQ on 20m during my activation on 40m because this station is located 4km from the summit … Amicalement, Nicolas
Hi Nicolas,
Yes I seen the F4VSQ RBN station was very closed to your summit :crazy_face:
73, Éric
Thanks Roger Summit corrected
73 sv2hjw Kostas
Hi all,
From Gérald @F6HBI last news :
First statistics
1108 QSO, uploaded on eQSL, QRZ.com, Sota Database.
Received 7 eQsl from SWL
17 different summits spread over 4 regions (FL/VL FL-NO F/AM F/CR).
661 in CW and 447 in SSB, on 9 bands from 60m to 6m.
56% on 40m, 15% on 30m, 21% on 20m
596 different chasers including Top-gun:
Thank you all (activators and chasers) for participating in the beginnings of TM15SOTA.
In general, the weather was very good during the four days of the Easter weekend, with a very average spread!
The list of enabled summits:
F/AM-207 F/AM-346 F/AM-385 F/AM-396 F/AM-462 F/AM-544 F/AM-617 F/AM-646 F/AM-651
FL/VL-038 FL/VL-049 FL/VL-052 FL/VL-070 FL/VL-007
F/CR-209 F/CR-229
FL/NO-042
You can follow the next days of activities on QRZ.COM
73, Éric
F5JKK
Hi all,
On the menu of the day : 23/04/2022
  • FL/VL-051
  • FL/VL-060
73, Éric
F5JKK
Hi all,
Today 24/04/2022 you can try to find TM15SOTA on F/AM-652
Op is Gérald @F6HBI
GL & 73 Éric
F5JKK
