TG Guatemala
Hello, I notice in the “Home Associations” section that TG Guatemala is NOT listed or mentioned, where in Guatemala there at least 37 volcanoes and several range of mounts !
Is there a reason for that ?
TU 73 de Juan TG9AJR EK44sl
Hi and welcome to SOTA. The main reason is simple: no Guatemalan hams have offered to help in forming a TG association. The next problem when that is resolved is whether there is suitably detailed mapping available (for free or low cost) so that a proper appraisal can be made.
In the first instance if you are prepared to help out the SOTA management with the formation of an association, use the “Contact SOTA” link at the top of these pages and fill in the form. There is a specific category for missing associations etc.
Hi and thank you for your reply.
I tried to “Contact SOTA” complete all the fields and made the comment but when cliking for submitting I get a message that reads “No captcha provide” and I do not get any captcha popup or message to verify the captcha, so I can not send the message to “Contact SOTA” so I am in a loop and yes if there is anything I can do to help to and from TG Guatemala, then here I am. Perhaps some from SOTA will read this message and contact me direct or if I get an email address I will send a direct message instead of the “Contact SOTA” that does not work from my end and I even tried in different browsers, all with the same message.
Send an email to reflector@sota.org.uk
Thanks and email sent, fingers crossed.
I thought the missing captcha was fixed. It should look like this
Often it’s privacy settings that stop the captcha box appearing. That screen grab was from Firefox with privacy blockers turned off as I trust the SOTA web domains. Likewise, it was fine for me on Brave with BraveShields down. Whilst that doesn’t help you directly now, explaining it here may help someone else in the future.
I don’t know where mails to reflector@… end up so for completeness Juan, can you forward a copy of the mail you sent to me personally at andy.gm4lld@gmail.com and I will force it through the contact form so the request ends up somewhere where the request can be tracked?
Thanks Andy, not sure what to say as with other websites that require Captcha or pop-ups I had never had an issue, and no still not showing the Captcha portion on the form (image attached), and I will forward you the email, thanks.
