Testing another new antenna on Scald Law
I have a 20/30/40 trapped EFHW from hamshop.cz ought years ago at Friedrichshafen when I happened to have a bag of Czech Crowns from a recent business trip to Prague. Normally I make antennas and don’t buy them but I had the cash so why not. I use it rather a lot now but I dumped the match unit and use either an AA5TB tunable match or a fixed 1:49 or 1:64 match and the KX2 ATU. Anyway I decided to make a backup because only having one you use a lot makes me insecure!
Having made it I had such confidence I didn’t test it but took it with up Scald Law, my local SOTA hill that involves a wee bit of exercise. 35mins drive to the parking place. Boots on and across the hard frozen ground, 1C according to the car but lots of ice, frost and snow higher up. Into IronMan mode and I was at the top in 46mins. Not bad as there were some real icy patches.
The wind was a bit cold and it was probably -2C at the top and well below -5C with the windchill. Down onto the steep sloping North side, it’s steep but covered in heather so it is easy to walk on even with 4-8 cm of snow. I was emptying my bag when I took out my Hagloffs Barrier jacket in its stuff sack. Really light and windproof and warm, 380 g and packs into 24 cm x 14cm tube. They’re not cheap, £220 is the list proce but I got mine in a sale. I dropped it and it bounced and rolled and bounced and rolled and the b@st@rd thing accelerated down the steeper than 1:1 slope. It started off just a bit faster than I felt safe trying to descend the hill and then got faster.
“Nooooooooooooooooooooooooooooooooooooooooooooooooooooo!” :sob:
OK it was gone. So as I was out of the wind I decided it’s just past midday, we’ll play with the new antenna till 1300Z then pack up and descend looking for the coat. There’s a path up from Logan Lea and the reservoir to the summit, so it would be down the steep slope to find the coat then contour round the path an up. Bu**er.
Anyway, the antenna. I saw a reel of Belden wire at a rally for pennies and bought… “I’ll find a use for that one day”. It is 0.85 mm OD, Teflon covered with 6* 0.25 mm Silver plated conductors. Is this too thin for an antenna? Let’s make one and find out! I bought two Pico traps from Sotabeams for 20m and 30m, wound them and tweaked for resonance using the old MFJ259b. I measured the hamshop.cz lengths and made a copy.
Will it work? Err yes! But being black wire < 1 mm diameter you cannot see it against a grey cloudy sky or blue sky. So it needs some warning streamers adding. Anyway measured as an inverted seven it reads the following SWR with the 1:49 match
40m 3.3:1 ???
30m 1.7:1
20m 1.7:1
17m 3.3:1
15m 2.7 :1
12m 2.6:1
10m 3.7:1
A tweak will make the 20/30 values go under 1.5 and that will do nicely. Something not quite right for 40m. Of course the KX2 ATU just laughed at having to tune such low values.
So that was the positive stuff. Does it work well 40 sounded different and quiet but I started on 30m CW. 16 QSOs: ON, EA2, G, GW, OH, GM, HB9, DL with OH3GZ being ODX. Again lots and lots of G/GM/GW stations worked at around 350km which is short for 30m. Then 15m CW and 14 QSOs: EA2, EA8, S5, LY, EA7, OK, SV, W4, EA1, DL. I’m not sure who was ODX just now either EC8ADS, W4GO or W4JKC. I had a quick bash on 10m and worked E72U. Turns out SFI was 174 but K was 4 and A was 23. Not brilliant conditions.
EDIT: W4 will be about 6000 km and EA8 is 3300 km.
Then it was 1300Z, so pack up time and at 1310 I started down the damned steep snow covered slopes. There a few places where there is no heather, just stones about the size of a fist that are dodgy to walk on when it’s dry, when it’s frozen and there’s ice, no way. I snaked down and then what’s that, yes my coat sat in a depression. Into the bag, out with a celebration KitKat and then do I contour round or be a man and go straight up. Straight up won! It took 25mins to descend then reascend back to the trig. It’s 1640Z and still very light here but I am about to go and find the Whisky :slight_smile:
A £200 jacket is too much to write-off. What annoys me is I have various bags that hold stuff when activating that are attached to the big rucksack so they cannot blow away. I never considered being Billy Butterfingers and dropping something and it rolling down the hill. As I was operating on a slope I made sure the KX2 was well and truly attached to the ground so it couldn’t fall away.
Well a bit more exercise than expected but all’s well that ends well.
Well done Andy,
I have lost a few items and several plastic bags to the wind and contours. In very windiy conditions years ago I had a Balaclava blow off my head and there is also a waterproof to be had on the crags on the East side of Red Pike.
I am not a fan on EFHW ants, the swrs you give remind me of a poorly matched dummy load. Please pass me a dipole.
David
G0EVV
It’s having a KX2 + ATU David.
KX2+ATU means anything from a damp (not even wet) noodle to a AN/FLR9 Elephant Cage can be made to work. When using radios lacking such an ATU means the dipoles/1/4wave GPs will be in the bag.
:beers:
It wasn’t long ago that we were sitting on a summit not far from there (on a MUCH warmer day) and I was working friends back home in W7 land with a 41’ EFRW and my KX2.
Glad you found your jacket!
Glad you got the coat back.
My forté is removing a section of yoga mat from my pack and it taking off in the wind. Happened twice, and I hate causing litter, so I am always annoyed. However, in both occasions the mat would have landed in a different Association.
… When I was operating on Top-o-Selside my 18 yr old daughter was with me and she had the dogs. I was playing with a 41ft wire and counterpoise and bluntly the dogs decided to run …As they ran the end of the 41ft wire the mast came down along with the wire and the KX2. I was left holding the microphone and no rig…which was now about six feet away, thankfully on nice soft heather… I suppose there are a couple of plus points to this, as the rig was no longer transmitting, and the microphone was no longer connected the tirade of licence breaking language was not being transmitted, and secondly amazingly nothing was broken. I now have the unun firmly pegged in the ground and the wire arranged so that it comes unclipped long before there is any force on the rig… PPS also lost a mat somewhere on Pike-o-Blisco but I doubt it is in the Lake District any longer…
Yes. I seem to always come back down with something to bin when I get home now.
Here’s a view from the summit, most of the snow seems to have been blown away, more snow on the Northern flanks out of the wind. Allermuir Hill GM/SS-171 in the far distance towards Edinburgh. Carnethy Hill is the near summit.
The loneliest tree in Scotland! Well at least in the Central Belt. More attempts at being artistic.
I lost a 1.8 x 1.2m tarp in a gale on Tinto GM/SS-064 many years ago. Unfortunately it was dark green… not ideal to spot amongst vegetation. I spent quite a while looking for it, but had to give up, hoping that whoever found it would dispose of it in an appropriate manner. Ever since then my tarps have fluorescent yellow tape on them. Of course that doesn’t reduce the distance they can fly.
Well done on recovering your coat Andy. I’m sure you’ll find some way of ensuring the tube is tethered to your backpack to avoid a recurrence… but then coat itself could of course take off before you got it on. :worried:
Better than you in a depression… :grinning:
Great when you find something like this.
Nice report.
My son lost a Grivel Spider instep crampon whilst on Helvellyn last year. It was extremely windy and we were blown off our feet a couple of times. I felt massively bad about leaving the crampon on the mountain but we couldn’t find it.
I liked those Grivel Spiders but now I only have one!
