I am not a fan of my 817. My issues: 1. I can barely even turn it on. The button is hard to get to. 2. I cannot see the swr on the tiny screen. 3. 2. 5 watts is barely good enough for CW and pretty useless on SSB. 4. The available after market antenna tuning devices are cumbersome to hook up and use. 5. To get the extra power you need an external battery.
The advantages of the kx2. 1. The button ergonomics are good. 2. I can see easily see the screen in full sunlight. 3. Ten watts available with the built in battery.
4. The energy drain on receive is light. 5. The built in antenna tuner works by pushing one button and whatever is hooked up is tuned in a 2 seconds. 6. There are attachable keys to the rig not requiring extra cabling and a place for you extra key. Hint, I use the paddle for the kx3 with the special shorter screw for the kx2. The kx3 paddle is now a good paddle since they fixed it.
When I finally get to the peak I just want to setup in under a minute. The kx2 allows that with an endfed antenna.
Of course your stamina may be different.
Richard
The batteries installed in my KX2 very quickly reached such a low voltage that the transmitting power was only 5W.
That’s why I only use them as a backup and always carry an external power supply that lasts me a whole day. With it, I can do several summits a day. It can also be charged in the car while driving to the next summit.
And yes - the built-in speaker is not exactly hifi. But in order not to disturb the tranquillity of the landscape (or other people), I’m using my headphones.
You what??? Man, that’s the easiest of the buttons to get to! IAEF, four fingers on the top cover and press with your thumb!
That gets me to the “home” or “sel” or “clar” buttons.
I find I need my glasses to see the screen on the 817 - and - probably just me but the power out icon usually leaves me confused and going back to the manual. ( I usually get the basic settings in a warm shack before the activatrion ) Somthing like turning on the noise blanker or changing the display - which would be easy in the shack becomes a bit of a trial and and a bit hit and miss with the menu. I have reached an age where I dont usually need glasses, but increasingly need them for close up work, so I’m discovering just how much fun they are on a mountain. Climb hill, set up radio and deploy antenna, check SWR, find glasses, check SWR, find cloth to clean sweaty glasses, check SWR, take glasses off whilst double checking links as SWR is high, open correct link, find glasses, find cleaning cloth, forget what I needed the glasses for… etc… I’m hoping the KX2 is easier! Paul
It depends on your visual acuity ![]()
- Varifocals (old pair for walking)
- Neck string for glasses (a la Larry Grayson)
Most of the time I don’t need them apart from reading GPS and my writing in log. I did print 1:25k maps at 200% so I could read without glasses. That swine, Old Father Time has made that no longer a guaranteed fix to reading a map without glasses. The glasses spend most time hanging on the cord when walking.
I own both ft817 & kx2. Happy with both. Those quoting the kx2 weight advantage doesn’t work with me when I compare the kx2 in its hard protective box against “throwing” the 817 in the rucksack. Additionally, the kudos of quoting serial numbers favours the kx2 ( mine is 355 btw
Ah! You’re either left handed or arachnodactyl!
194 mine nahnahnananaaaa!
A small scratch Brian - incredible from a 20 lb rock!
Small scratch = what the nurse tells you when you get the Covid jab!
73 Phil
I quite agree - I thought that the rig couldn’t have survived!
I was slow off the mark with the KX2 as I wasn’t really sure about it and only scored serial number 116 but I did better on my first and now only KX3 scoring serial number 30.
Paul
I’m right handed. So I put four fingers of my right hand ( the one I do most things with) on the top and my thumb was by the buttons mentioned.
It’s not my fault your instructions were imprecise, I’d advise against a career in programming!
I don’t understand the appeal of hard protective boxes. I put my KX2 into a soft case (LowePro) and toss that into my backpack and it works great. The KX2 isn’t made of glass.
Agreed - also have the Lowe Pro square soft case, well travelled, no problem and no damage. Three of us clubbed together to save the high carriage costs and we got the side plates from the USA a few years since - they help cosset the controls and perspex glass front very well. I think they also provide a little more heat dissipation too.
Ooooh Phil, you’re such a tease
The top and bottom case covers on mine resemble aluminium beer can material, not something I’d think would protect a radio from falling rocks. Amazing story, really.
Au contraire - they are 1mm steel, and are 300g of the radios weight - more than the battery pack.
However mine slipped out of my fingers in the lounge, fell about 18" onto the carpet, landing on the volume/squelch knob. Bent the shaft which subsequently broke. Even though 818’s are current production, a replacement pot was unobtainable. Cue a good few hours pulling the pot completely apart and pinning the shaft together again on the lathe.
I don’t know if that has already been mentioned. I don’t want to miss two advantages of the KX2 and I use it every time I activate.
- The built-in memory for cq calls in ssb and cw. Also useful to test the propagation with the reverse beacon network.
- The cw decoder as an aid in my first attempts at telegraphy.
