On the Summit Report page, the hotlink assigned to the “View” page has lost its connection. Don’t know if its just me? Is this link good for other folks?
Thanks, Guy/n7un
Thanks, Guy/n7un
Guy, can you post a URL where this is broken so we can check things?
I start at SOTA Database then choose any summit “to find”, e.g. w4v/sh-027. This brings up the Summit Report page where the “View” link for “Extra Info” is grayed out. No way to get to the Extra Info via this link.
There is a backdoor. By clicking on the “Map”, you can then click on the hotlink on the SOTA Mapping Page for this summit which then takes you to the “Extra Info” page.
Guy/n7un
Oh yes, it’s all borked. I’ll see what I broke when I added multi language support.
Sorted. Rather too much cutting when fixing the URL for Sotamaps a while back.
Trivially easy to fix since I started using git at home to maintain the source code repositories for the database, SMS spotter and cluster. A quick “git log -p …” showed the two lines deleted in error. All fixed now.
