HI,
while qrv today from EI/IE-002 both myself and John EI3ISB worked stations giving a summit ref of FL/VO-*** . As I don’t see this ref on the Sota database I assume it’s some other award programme, DMA perhaps ? Anybody clarify ?
Dec
ei6fr
HI,
Dec
ei6fr
I see spots for at least eight matching SOTA summits today, FL/VO-001, FL/VO-017, FL/VO-021, FL/VO-078, FL/VO-080, FL/VO-082, FL/VO-170 and FL/VO-172. They’re all in the SOTA database.
Hhhhmm, I was not seeing FL in the dropdown for France when I tried to log a S2S qso, will check again
Thanks
Dec
Dropdown for France F/AM-AB-CR-MC-PO-PE…
Dropdown for FranceLow FL/NO-VO-SO…
Good luck
OK, I should have scrolled further down the page, I found FL down the list, I assumed it was under F
Thanks
Declan
The old French association got split in two in February 2017 so that the less mountainous parts of France could be P100 while the more mountainous bits remained P150.
