The csv-download of all summit lists looks to be broken, returning only first 10 or so summits - not the complete list.
73 & gl
Axel, DL6KVA
73 & gl
Axel, DL6KVA
In reply to DL6KVA:
I don’t think so. 47k summits in the version I just downloaded.
Andy, where did You get it from?
I usually go to “Database” => Summits => List of all Summits => than I use the link in the lower part to download a csv-list of all summits. Download now gives a 1.2k file with a few summits (9H and a few CT) for me …
Any other place I can find that?
Thanks!
Axel, DL6KVA
In reply to DL6KVA:
That’s how I download it. I just tried again, 5.9MiB downloaded using Firefox 3.6.25 on WinXP. Also I ftp’d to the server and checked, again file downloaded and it was the latest version, created this morning 0429Z Dec 26.
I have the same result with Opera 11.60.178.
The entire list of SOTA 9H-ZS!
summitslist.csv 6.204.932 k 16:56
Axel, because now I do not know if you need it most urgent, I have even uploaded for you.
Axel, da ich jetzt nicht wusste ob DU sie dringenst benötigst, habe ich sie mal für Dich hochgeladen.
www.megaupload.com/?d=6MLMBHCA
44 Peter
Hi Axel
Although I’m using Chrome, I get exactly the same file downloaded as Andy.
73 ES HNY Marc G0AZS
Thanks to everybody!
Looks like some download problem with the current Firefox installed here (or some settings) … download says it’s 5.9 MB but all I get is a 1.2 kB file.
So have to check what’s wrong here
73 & gl,
Axel, DL6KVA
proved: download works ok with firefox 8.0.1, but not with new version 9.0.1.
73 & gl
Axel, DL6KVA
In reply to DL6KVA:
I’ve just installed Firefox 9.0.1 here on one of the Linux laptops (Debian 32bit x86 Squeeze 6.0.3). I did this for 2 reasons. One was to check out this issue and if necessary raise a bug with Mozilla. The other was the announcement that security support for Firefox 3.x finishes in a few months.
Firstly, clicking the link on the database downloads the full file. At first I thought it was failing as you had found. But it was just downloading very fast as I was getting about 1.6Mbytes/sec from the server! I tried several times and everytime the full file was downloaded. I’m not sure what the issue was but I can’t repeat it here. Perhaps it’s a Windows Firefox issue or maybe 64bit?
Slightly OT, I’ve stayed on Firefox 3.x as the later versions insisted on playing with the UI and looking like a 5yr old had been let loose with some fluorescent crayons but 9.0.1 on this machine looks almost the same as 3.x. I’ll try a Windows version later.
In reply to DL6KVA:
Hi Axel.
I just updated Firefox to 9.0.1 and followed your instructions. Saved the file (5.9MB) and it opened OK with all summits I guess - well there were 47,746 rows!
Using W7 64-bit.
Reg
G3WPF
In reply to G3WPF:
pretty strange of course. Here I’m using Windows 7 64 bit.
Had the same problem with all versions I tried up from Firefox 9, 10 etc. The download was quick, the file was small and when I opend it it contained only 12 rows or so.
But the download works ok with a standard version of Firefox 8. So I reinstalled this one.
Didn’t invest more as I was happy to get a stable version again using the Firefox 8 installation I found.
Axel, DL6KVA
