I’m new to SOTA and haven’t logged before so I may be doing it wrong, but when I go to submit my first SOTA activation on newsotadata.sota.org, I get the error message:
Submit Activation Log
An error occurred while uploading your activation: [object Object]
Q. Whom should I contact if I have a problem using any of the SOTA facilities or understanding any of the rules?
A. If you go to the SOTA website and go to the About SOTA page, you will find a list of members of the MT and their areas of responsibility within SOTA, each member has a contact button so that you can send them an e-mail.
Also you will need to make the log file available as without the file, nobody can seriously help. It will probably be something simple that is easy to overlook.
