Stony Cold Pike
I took an opportunity today to make good use of the winter bonus again. With the clock reset, and potentially poor visibility, Stony Cove Pike was a good option. Up from Kirkstone Pass, once you have summitted Raven Crag it is an easy navigation - keep the wall on your left-hand side until you reach the top. No views to be had today, wind was around 5 knots at the top with estimated temperature of -2 degC.
I didn’t think I’d unpacked my rucksack, but when checking the content at the top of Kirkstone I found that my EFHW was missing (extracted to be dried) so the FT-817 and battery was ditched, keeping the tactical mast and Spectrum Comms Slim-J for a 2m only activation using the FT1XD.
My Lora tracker was charged beforehand and, with continuing improvement coverage of 70cm APRS via Lora I was able to be tracked from Raven Crag to the summit.
I caught Roy @M0TKF on the summit of Helvellyn G/LD-003, working a nice pile up and apparently surrounded by Muggles. Myself, I saw three folk and followed a solitary set of footprints all the way up.
Great to get Andy @MM7MOX and Chris @MM0UHR S2S on GM/SS-133, Tim @G5OLD was on the ascent to The Old Man of Coniston and has been making the most of SOTA in the LD over the past few days.
TIME CALLSIGN BAND MODE RST RSR OPERATOR SIG REF
11:52 G6AEK 2m FM 59 59 David
11:53 G7CDA 2m FM 59 59 Douggie
11:55 G0TDM 2m FM 59 58 John
11:56 G5OLD/P 2m FM 59 59 Tim
11:58 GM4WHA 2m FM 59 55 GEOFF
11:58 MM7MOX/P 2m FM 59 59 Andy SOTA GM/SS-133
12:00 MM0UHR/P 2m FM 57 59 Chris SOTA GM/SS-133
12:01 G1FVA 2m FM 59 59 Keith
12:02 MW0SZR 2m FM 59 55 Adrian
12:02 G0MHF 2m FM 58 59 John
12:03 M0SSD 2m FM 59 59 George
12:12 G6ZET 2m FM 59 59 DAVID
Hi Mark,
It was good to get you today. 2m was very difficult for me but 10m got me everything I needed for my hill and more.
Chris
Good to catch you today.
2m was only good for s2s G/LD stations today from GM/SS-133.
Cloudy to start then cleared later as we packed up.
Great to get you today Mark @M0NOM on the way up the old man G/LD-013.
And extra thanks for the complete from my ascent of Stoney Cove pike on Thursday!
I was hit by a solar flare on summit meaning HF conditions were not great, you didn’t miss out ! But I did hear your excellent QSO with @MM7MOX and I wasn’t fast enough onto the summit to give this a try!
