With Monday and Tuesday off work, and a free weekend before, I’d sort of had the plan to return to EA6 or similar. But the short-term weather for Mallorca didn’t look great, so I decided not to book it, and head elsewhere instead…
With South Wales looking like the winter sun destination of choice, I grabbed a few nights accommodation, decided on a first couple of summits, and threw some radio kit and the coffee machine in the car.
Saturday started with a surprisingly good run down from Cambridge, and I squeezed the three originally-planned summits, plus a fourth drive-on I’d originally slated for Sunday morning:
- GW/SW-040 - a very pleasant walk in just a t-shirt(!)
- GW/SW-029 - a few minutes drive down the road, then an equally short run up to the communication masts
- GW/SW-039 - a longer drive, but another short (600m) walk to the top
- GW/SW-036 - barely more than a drive-on, but I made the point of getting as close to the trig point as I could, even if the parking spot was in the AZ!
At this point, Colin @G8TMV and I had been chasing each other around GW/SW for a while, and it turned out we weren’t staying too far away from each other, so managed to meet up at the Castle Inn near Swansea for an excellent burger - and the obligatory “clearly deserved after all that walking” desert.
After that, it was time to plot the next day’s route - ending up near Cardigan, and with a stop for EV charging, I was confident I could manage four summits, but the obvious fifth choice would be touch and go on daylight:
- GW/MW-036 - starting the day with a short but pleasant walk, sunrise by the trig point was a great start. The occupant of one of the nearby houses popped by to see what I was up to, but was entirely happy as long as I didn’t stick anything in the scheduled monument!
- GW/MW-037 - a drive-on, activating by the side of the road with powerline noise and nowhere decent to sit, I was happy to move on from this one…
- GW/MW-028 - the fog had descended for this one; thankfully not too wet, but rather different to the blue skies of the morning’s activation!
- GW/MW-011 - an actual two pointer! And it felt like you deserved the points as well, with the 3km walk in, and a significant wind on the summit. Another rather fog-cloaked activation, removing what I’m sure would’ve been a very fine view in the clear.
- GW/MW-033 - this one was deceptively hard work; from the parking spot at the base of the incline, it looks like it’s just ahead of you, but a mix of some slightly poor route choice on the way up and a bit of a hidden summit meant it was actually a decent effort. But the sunset made it very much worthwhile! The head torch was needed for the descent, though thankfully I found a rather better path on the first section than I had on the ascent.
I’d arranged to meet Tim GW4VXE / GW4MM and his wife for dinner in Fishguard, and it was great to say hello in person after many QSOs, and too many years of only speaking on air and on Zoom. Tim’s recommendation of the Royal Oak was spot on - both the lasagne and chocolate brownie!
Onwards to Gwbert to find my hotel, and see what I could attack on Monday! The Cliff Hotel was, amazingly, the cheapest accommodation in the area, but very pleasant, and served an excellent breakfast looking out over Cardigan Bay.
And so to the third day of summits:
- GW/MW-029 - a decent drive, but a short hike to start the day, again with excellent weather!
- GW/MW-035 - another quick one, just up a track from the road
- GW/MW-021 - now for the first real walk of the day! Taking the route up from the chapel, it’s not a huge distance, but the ascent means your legs will have woken up by the end!
- GW/MW-034 - another good activation, starting from the Abbey, along decent tracks, similar ascent to 021.
- GW/SW-022 - my penultimate GW/SW summit, and thanks to a very useful note from GW4ZHI on the newly-surface track, a rather shorter walk than I’d originally planned for - you can now drive to 51.88651,-3.89893 without difficulty, and there’s space for a car or two there before you head onwards on foot.
Back to the Travelodge Cross Hands for the final night, and to see what I could squeeze in before the journey back East on Tuesday afternoon:
- GW/MW-003 - the longest walk of the weekend. I took the PROW just West of the forestry road described in GW4VPX’s route and… well, it gives strong “we accept this is a right of way but have no intention of maintaining it in a usable state” vibes. Lots of wading through bracken and small Christmas trees until you cross the forest road at 52.19182,-3.69189, after which it’s in much better condition and the rest of the walk is easy by comparison.
- GW/MW-016 - G4OBK’s track remains perfect, taking you easily to the trig point in a small clearing, surrounded by forest that must’ve significantly limited its utility!
- GW/SW-018 - having heard what I suspect was military training activity while activating MW-016, I was unsurprised to find the red flags flying as I approached this one. Rather than find the true summit, I took advantage of the Epynt Way remaining open during firing times, and activated from the little information shelter for the final summit of the trip.
And so, back home: 17 summits, all uniques for me, and GW/SW now fully activated along with a useful chunk of GW/MW ticked off.
Thanks to so many of you for the chases - and especially for putting up with my even worse than usual CW sending - my newer TUMD paddle seems to have got a grubby contact on the dash paddle; I swapped back to the older Palm which has a slightly less intermittent connection on the dot side instead! And I’ll try and figure out what’s going on with the 2m SSB audio on the 818, which got a rare outing on a few summits this trip…
Rob, M0VFC
