Early today I am unable to reach SOTAwatch. Can anybody else reproduce this problem? (Windows 10, 64 bit / Chrome)
73, Alfred, OE5AKM
73, Alfred, OE5AKM
This link is ok! Thank you!
73, Alfred, OE5AKM
My apologies, we are experiencing stability problems on the server on which SOTAwatch2 is hosted.
SOTAwatch3 is available to use and as John VK4TJ has pointed out can be accessed here: https://sotawatch.sota.org.uk/
I was going to be annoucing the retirement of SOTAwatch2 before too long anyway so feel free to start switching across (he says with trepidation!). You can log into SOTAwatch3 using the same credentials as you use on the SOTA Database.
There are still a few rough edges and loose ends so it would be extremely helpful to me if you can feedback any and all issues you do encounter and I’ll do my best to address them. The best method is probably by sending me a private reflector message or failing that via the SOTA contact page.
73, Jon
Thank you Jon. Your work on this is much appreciated. SOTAwatch is a fantastic tool!
-Josh
