For the previous I had text after the line with quotes. After I had posted it the quotes were OK so I edited it and deleted the last line of normal text, went in and out of spell check and then slashes appeared when I posted. Editing it and adding the last line made the single slashes into triples.
In reply to GM4ZFZ:
Hi Jon
I think I’ve found another glitch - just checking Summits worked and it seems that the listing is not being updated, for example - on 3/8/09 I worked G4ERP on G/LD-051 and also DL/PA3FYG on DM/BW-313 both being unique for me, but the listing shows them as still being needed.
Thanks Graham. I had hoped no-one would notice this!
This will fix itself once I set up the automated nightly processes that do stuff like pull in the latest chaser logs and send out the digest emails etc. Hoping to get this done today.
In reply to GM4ZFZ:
Cheers Jon, no problem, I thought it might be due to the overnight update, but thought I’d mention it in case you hadn’t noticed it.
With the recent debate about “listing of first activator” on the summit details, there are, or were 2 ways of looking at the info. The first (incorrect method) is through the drop down list on this page. The second method which used to show the correct order (ie by time & date) was through the database by finding the summit & then clicking on info. I have just tried this method on a few summits but I`m getting a “page can not be displayed” message. Maybe a glitch from the server change over??
Hi Gerald - adding “live” to the url just points you back to the same summit info page with the “wrong” first activator info. Going through the database used to point you to a different summit info page where the activators were listed in the correct order - ie when 2 activators did a virgin summit, the one with the earlier times got the credit for being first. Maybe this other page is now redundant as part of the upgrades & improvements. This topic was discussed in a thread started by a HA staion a year or two ago, but I can`t find it.
I don’t ever recall seeing those pages. Maybe just because I haven’t tried or maybe it was before my time, Hi Hi! With regards to the previous thread on the subject, maybe you should look on the old reflector. Time flies when you’re having fun. Was it really 2006 when I started???
In reply to GM4ZFZ:
Hi, Jon. Try Database>Summits>List of summits>Association>Region>summit name>info. I don’t get what Steve got, it just times out for me!
I wonder whether Steve is looking for the information given under History rather than Info on the page which is accessed thus -
Database>Summits>List of all summits>Association>Region>Summit name>History
I don’t recall seeing anything other than that info and the info given on the individual summit pages. You pre-date me as far as SOTA is concerned Brian, so maybe you know more.
Anyway, the Info link is broken as Aleksandr has said… darn Meerkat used my log-in details. Sergey must have hacked my account!
Jon - Brian had the correct sequence of clicks. I`ve tried at home on Firefox where it times out, at work on IE it gives the page can not be displayed message. However, in the past it used to point to a summit info page slightly different to the one you get going through the home page. Maybe this is redundant now, but if so maybe you can re-direct the link to the “new” info page. Obviously the message you see is browser dependant.
I have changed the DNS for http://sotwatch.org/ It might take a day or for it to propogate but after that it should be fine I think. Let’s check tomorrow.
Meanwhile, sticking the ‘www’ in the address bar of your browser should solve the problem.
I am also gradually putting together a new summit page on the website with some new mapping options. Try here: Summits on the Air
Click on a summit.
Any suggestions since I am starting from scratch here? Btw, this will eventually replace the SOTAwatch summits page once complete and everyone is happy with it.
check tomorrow.
