Occasionally I bring my Google Nexus 7 tablet on activations. Using its Google Chrome browser to self spot is very cumbersome and slow. Are there any Android apps available or in development that would allow me to pre-configure spotting information for multiple potential spots at home before the activation and then once on the summit, quickly choose/edit the spot info and send it?
In reply to DG0JMB:
Thanks Juerg, I’ll give that app a try although it doesn’t offer the pre-configured spotting info - you still need to manually enter each form field. (correction: it prefills your sota ref automagically)
There is also ‘DroidSpot NA’ and ‘DroidSpot EU’ in the Google Play Store. These two apps send SMS spots to the SotaWatch site. No GPS or 3G connection required. All it does is formats the SMS message in the correct form so you don’t have to think about it.
If you search for DroidSpot in the Play store the correct version for your area will appear. The only difference between the two is the phone number it sends the SMS.
I used the app for the first time yesterday from W2/EH-001. It seemed to work well. Evidently for any recently spotted station, it only displays the latest spot for that station and doesn’t display previous spots.
Translator
"Own position is based on GPS or the mobile network. In the first line before the locator is accordingly “GPS” or "network.“Â If you want to determine the location via GPS, it should turn on before starting the app. The position is determined by GPS takes a relatively long time but when you start. For a quick start, is therefore prior to loading the mountain waiting list only briefly to a position statement from the mobile network, which only takes a few seconds. If GPS is on, then switches to the app on GPS, which allows a much more accurate positioning. Alternatively, you can just turn the GPS on the Android menu key and then later in the app twice on the compass.”
I think you’re saying to turn on the Android GPS before starting the
App? How do you manually turn on the Android GPS?
Barry N1EU
Barry,
Yes it’s done through the settings options, however it’s quicker and easier if you use a widget.
if you’re using the Nexus 7 it already comes with a widget to do this.
Select the menu button (circle with 6 squares in it).
Select widgets
Scroll through the pages until you see the Power control widget.
Drag it to the an appropriate place on your “desktop”
That’s it. You can now quickly toggle GPS on and off, along with wifi,Bluetooth, GPS, auto updates, display brightness.
