Monday, 12. of May I will start a march from the Ruhr region to Friedrichshafen. On my route there are 40 summits. I hope to activate the most of them and to arrive in time at the HAM-RADIO. I will be active mostly on 40m cw (not high speed) and 2m fm.
In reply to DK2MT:
That sounds as a long and active walk Volker!
Wish You good luck and nice weather on the way to Friedrichshafen and a lot of activity from the summits!
What rig/ antenne You are using and how many KM is the trip in total?
Your callsign brought back memories from the early days of SOTA. Great to see you are still out and about. And I guess our SOTA paths keeping missing these days?
In reply to PA0XAW:
About 860km from JO31NR to Friedrichshafen.
I am using a KX3, mast and antenna-wire from DX-Wire, can be used as inverted-v or vertical,
for 2m a TH-F7
missing these days?
73 es look fwd to wrkg u soon.
Jack(;>J
GM4COX
Hello Jack, I am still alive HI. Not so active with SOTA as it used to be. Sniffing a lot of solder smoke those days when in the shack, but do some chasing when I need a rest.
I guess You are still going out for some activation so will keep an eye on the alerts for Your callsign.
