sota map errors?
getting this error every couple of minutes on sota maps? have took screenshots as it wouldnt let me copy and paste the text. needes 2 as the error scrolled down.
i should say the site seems to work if i click past the error. Just thought i’d let ppl know.
I am experiencing the same error when using the site. When I click past the error, it just reoccurs a few seconds later making it almost impossible to use. I’ve tried different browsers and devices with no change.
Working fine for me on Firefox 141.0.3 / Debian 13 with NoScript, uBlock Origin, Ghostery, ClearURLs. The error comes up when I use Brave.
I’d try it with Edge but I don’t run Windows any more… laughs uncontrollably with joy!
Will someone use the contact MT form so it this issue gets recorded?
Sent.
Seen error in Safari on iOS too.
Update:
Happened to be speaking to a friend who knows php, and said it looks like the issue is the IP address to geolocation (the filename gives a clue :sweat_smile:) translation and whatever service is being used has probably stopped working. So updating to another one should fix the issue. For example, https://www.ip2location.io/ gives 50k queries a month for free.
