Stinky the Goat may have slipped on a rocky outcrop, but he has regained his footing and is back on the summit!
SOTA Goat has returned to the iOS App Store. It may take a few hours to become available in your country. iOS 11+ is required.
New features
Integration with SOTAwatch3 spots and alerts
Improved spot and alert submission forms
Real-time summit search by name or designator
UI support for newer devices: bigger screens and dark mode
Bug fixes
The summit database update is fixed - it correctly handles the new summitslist.csv formatting
New alerts will be posted with the correct time zone offset
Coming soon
Iāve already started working on push notifications, which will have an abundance of new options. You will be able to configure multiple notifications depending on criteria such as mode, SOTA region, and activator callsign.
The app also needs a lot of general polish and usability improvements, but I wanted to get this back into the hands of the SOTA sloths and goats in a functional format as quickly as possible.
So, what happened?
With recent updates to SOTAwatch breaking most of the core functionality of the old version, I removed it from the App Store so folks wouldnāt waste their hard-earned $2.99. I hadnāt anticipated the inability of existing customers to reinstall the application.
I also didnāt realize just how many of you folks use the app and rely on it every day. I havenāt done a SOTA activation in years, so the app became low priority. All my development bandwidth is focused on RemoteHamRadio these days.
After seeing many frustrated and upset users here, it became clear that the app really does require continued support. I made some time to write a whole new back-end server, integrate it with SOTAwatch3, and update the app to work with the new server and the latest core iOS features.
I hope update works well for everyone. You can post bugs or feature requests in this thread, tweet me at @WW1X, or shoot me an e-mail at schrockwell@gmail.com.
Many thanks for your efforts Rockwell! Unfortunately it appears I need a new iPhone as my 5s iPhone doesnāt support beyond ios 10.3 ;-(. Your app isnāt the only one I have issues with in this regard so I guess Iāll finally get a new phone!
I have to disagree with this. There are already many great logging programs out there.
Recognizing that this isnāt WW1Xās main gig, and he isnāt making money off thisā¦ Iām very happy with the plan to focus on āgeneral polish and usability improvementsā.
Rockwell - Iāve had some time to check the various parts of the new Goat and it all works great. I really appreciate being able to locate summits, and go directly to Google Maps for directions. Even if I know the way the maps function allows me to determine the travel duration so I can set up my alert appropriately! Great work and many thanks.
Yes! Available in VK app store! (apple doesnāt call it that). Updated on the phone, app looks good, posted an alert. Required logging on using the sso user id, ok no problem. A minor glitch when the time defaulted to local time so the UTC time chosen resulted in an incorrect alert time, but no problem, fixed that with time setting and updated the alert using the edit alert function. Time corrected. No mental arithmetic required now. Will report any glitches.
Thanks Rockwell @WW1X!
73 Andrew VK1DA/VK2UH
Great! There is a setting to use UTC or local time throughout the app, but the alert form doesnāt honor that setting right now, and it defaults to local time. Will change that in the future.
Thanks for the return of this vy nice app. Iām using it every day. And itās a good app for SOTA.
Only one minor future suggestion : map scale. Vy handy when you are walking to the top of a summit. Then you can estimate the distance to the summit.
Can you tell me a little more about this use case? What are you really trying to do - measure the distance between yourself and the summit, or measure distance between two arbitrary points on the map?
