There’s nothing wrong with either my keyboard or chair, and if theres any ID107 fails they
re not from my end.
Mike 2E0YYY
re not from my end.
Mike 2E0YYY
A further update to the CSV Editor with a number of enhancements has been published on my site.
I found V0.9.3.5 and V0.9.3.6 had a fault when used on XP that caused the program to crash when some warning messages were displayed, that could have resulted in the program not saving changes to the log. (Note to self: Must test it more on XP before releasing updates).
Those that already have the program installed can simply click ‘Check for Update’ in Help → About or you can download the ZIP to install yourself from
http://www.g0lgs.co.uk/soft_info.php?AppName=sotacsveditor
F1 brings up a Windows Help file (PDF version is included too) which has all the important details (See version history).
Stewart G0LGS
Various updates have been made to my CSV Editor since my last post here.
Details are in the Docs.
(use link in previous post or Select Help->About->Check for Update from the your installed version.
(Activators might want to wait for the next update before using the ADIF export - as I still have on-going work in that part of the code)
Stewart G0LGS
