Hi,
I have been informed that in some circumstances SOTA CSV Editor V1.5.8.2 or V1.5.8.3 does not quite work as expected when loading logs with QSOs for the 10MHz or 18MHz bands and that it may add incorrect QRG information into the comments.
I have just released V1.5.8.4 which should address this issue, but if you have logs with the incorrect QRG information you will need to edit affected lines to correct them.
See SOTA CSV Editor
