G3CWI
20 April 2021 06:59
63
I believe that the 44 ft doublet as a system may have come from the work of LB Cebik W4RNL. He did a lot of work on this. A summary is here. http://www.n5dux.com/ham/files/pdf/W4RNL%20-%20Top%20Five%20Backyard%20Multi-Band%20Wire%20HF%20Antennas.pdf
More here: The All-Band Doublet
And here: Only One Wire
The NORCAL doublet was suggested by Doug Hendricks - KI6DS
N1EU
20 April 2021 07:50
64
The red and green number display is in column C, not column D. I believe it’s the column C numbers that must avoid multiples of 0.5, correct?
For CAT5e velocity factor of 0.64 , feedline lengths of 7.6-7.8m are favorable.
Thanks & 73,
Barry N1EU
Hey Barry
of course you are right. I have corrected it.
The total length of the system (radiator and feeder) should not be a multiple of 0.5 lambda.
Armin,
thanks for finding the original spreadsheet and the translation, that’s excellent. Hopefully it will help people find a good feedline length for their doublet.
73 Gavin
GM0GAV
