I planned to return to the Lake District on Saturday December 10, 2022 and attempt to activate my last two remaining summits: G/LD-036 - Mellbreak and G/LD-031 - Blake Fell.
If successful, I would not only have activated (and qualified) all 55 summits in the Lake District, but all 174 ‘G’ summits within the 2022 calendar year.
Snowy and icy conditions on large stretches of the M6 motorway hampered progress. The southbound M6 was blocked after a car had turned on its side in the middle lane. I was heading North and saw a van on the hard shoulder (breakdown lane) on its side and not much further a car, also on the hard shoulder, facing the wrong way. I took my time and had to adjust my alert time.
The approach roads to the first summit were generally OK except in a few places on very minor roads where the car struggled a bit but got me safely to my first parking spot.
The planned parking spot was blocked off by some large tree trunks to prevent people from parking there, so decided to park at the Kirkstile Inn, as all places at my alternative parking place near the telephone box were taken.
I had seen some imposing pictures of Mellbreak before; in real life she does look very impressive for a 2-pointer.
My planned route would be the easiest, but the longest, a bit over 4.6km (just shy of 3 miles) climbing from 111m to 512m with a total ascent of 414m. Heading South along the valley flanked by Little Dodd (355m) and Hen Comb (509m) on my right, with an approach from the South. I was tempted with the shortcut from the West but noticed two walkers struggling to come down from there, so decided to stick with my original plan.
©Crown copyright 2022 Ordnance Survey. Media 041/22
The sun was out, visibility was good and I made good progress on frozen ground.
As I reached the summit I noticed I had no phone signal; restarting my phone did not help, so VHF only as I had not taken my APRS capable HH as backup.
I made 5 contacts in 15 minutes and had a good chat with regular chasers Derek (@2E0MIX), Reg (@2E0LDF), Steve (2E0XUP) (@M7XUP) operating mobile, Matthew (@M0MZB) and Richard (@2E0XGO) who was operating portable, previously M7MGO and who last month passed his intermediate. Congrats Richard!
I made my way down back to the car but had to use a different route to the next one as a car was stuck up a hill unable to go up and sliding down.
Equipment used (for both activations):
- Yaesu FT-65E
- Spectrum Communications Slim G
- Sotabeams Tactical Mini pole.
QSOs logged:
Time | Callsign | Band | Mode | Notes |
12:37 | 2E0MIX | 144MHz | FM | 59/59 |
12:41 | 2E0LDF | 144MHz | FM | 59/59 |
12:45 | 2E0XUP/M | 144MHz | FM | 59/55 |
12:49 | M0MZB | 144MHz | FM | 57/54 |
12:52 | 2E0XGO/P | 144MHz | FM | 56/59 |
After leaving the Felldyke car park, I made my way in the direction of Cogra Moss Reservoir, normally used for fishing but today it was fully frozen over.
Knock Murton (447m) was on my right and I could see Blake Fell for most of the walk in the distance - with the lower High Hows (313m) and Sharp Knott (482m) to the West of it - as I climbed from 200m to 573m with a total ascent of 389m.
I headed South through the wooded area to higher ground and at the clearing turned East following the fence line on my right all the way to the summit in anti-clockwise direction.
It was getting darker causing the light to get the blue-ish tint you get when there’s snow on the ground.
After layering up, I set-up in the cairn taking some shelter. There was hardly any wind, but it started to get noticeably colder.
I made 12 contacts on VHF in a little over 15 minutes, the first being Reg (@2E0LDF) who was able to see Blake Fell from his QTH. I shone my head torch in his direction and he acknowledged he saw my torch light.
I was very pleased to make contact with so many regular local chasers also on this final summit including Geoff ( @GM4WHA ), Sue (@G1OHH) and Lee (@2E0LLB) . A big thank you for all your support this year, sharing your local knowledge along the way.
I had alerted for HF as well, but by the time I finished my activation on 2m FM I really started to feel the cold. I was in two minds whether to setup for 40/20m; my heart said yes but my head said no, so I packed up.
It took a little while to get warm again as I made my way back down. Whilst I felt bad I was not able to share this last summit with the regular HF chasers and thank them for their support, my decision to call it a day was the right one.
QSOs logged:
16:27 | 2E0LDF | 144MHz | FM | 59/59 |
16:29 | 2E0MIX | 144MHz | FM | 59/59 |
16:31 | GM6TVR | 144MHz | FM | 59/31 |
16:32 | G1OHH | 144MHz | FM | 57/53 |
16:33 | 2E0IKM | 144MHz | FM | 59/59 |
16:34 | GM6LJE | 144MHz | FM | 59/59 |
16:35 | GM4WHA/M | 144MHz | FM | 59/59 |
16:36 | 2E0LLB | 144MHz | FM | 59/59 |
16:37 | M0MZB | 144MHz | FM | 59/59 |
16:38 | 2E0XUP | 144MHz | FM | 59/59 |
16:41 | G4YTD | 144MHz | FM | 56/56 |
16:44 | GI4UPC | 144MHz | FM | 56/56 |
Thanks again to all the chasers as always!
73, Robert
M0RWX
