Set off super early and do Arnside Knott instead? ![]()
Hi Marek,
thanks for checking this with VOACAP. These are interesting results. 15m certainly could be possible - especially with a QTH further south or east. Personally I would be rather surprised if 10m worked at that time, at least in DL but it could be possible from your location.
I haven’t run a VOACAP simulation myself, so I can’t say why it gives you 0% on 20m. The reason for suggesting 20m is mainly practical experience. The LP to VK/ZL on 20m is pretty reliable from my location, particularly around equinox. Contacts are possible even with low power and simple wire antennas.
So I think 20m could be used as a starting point. But there is certainly room to try other bands as well. 17m, 15m and even 10m could be worth considering, depending on conditions on that day.
73, Roman
I would if other people wernt involved
I’m not sure they’d be happy about a 6am pickup time for a 1 hour drive to a lunchtime appointment and in October I am even more certain they wont be wanting to stand around on a hill at that time ![]()
I don’t understand the above statement.
Andrew VK1AD
…how happy are you with your thingy’s ![]()
Last Wednesday Andrew VK1DA made numerous 20m SOTA CW contacts into Europe. Yesterday Sam VK3WSM was successful with 20m SSB contacts into Europe.
I have had a decade of 20m SSB EU LP success from SOTA summits in VK1 and VK2.
Actually very happy with my thingies (Le SLug Rouge). I can’t say I’ve used them much, but on the occaision I have the normal vertical + radial configuration worked very well with qsos into eastern USA and a South African summit to summit on 10m.
With 2 telescopic whips, I managed to contruct a makeshift 6m dipole that got qsos into Italy , so its actually pretty versatile too.
Next time I’ll use a Whatsit into a thingy fed by an oojit ![]()
Hi Roman,
I have been regularly operating LP QRP SSB 20m portable into VK over the last 2-3 months from local parks (and last week from 5B Cyprus). I would say I had more success from 05:30 UTC (07:30 local in DL). While 06:30 UTC may still work, earlier has been better. Of course, we need to factor in how long we will need to get to a summit and what the light level is, when we get there. On the VK-SOTA email list, a date earlier in October was originally proposed due to the light issue.
By the way, for the last few sessions I have been using a parasitic vertical array based on the “red slug” 1/4 wave vertical plus a reflector, and it works rather well, giving about an S-point signal improvement both on RX and Tx.
73 Ed DD5LP (VK2JI)
Hello,
Right now 06:04 utc, I had a pleasant LP QSO with VK2GR in 14 mhz.
I’ll try joining this event, most probably 10w and vertical EFHW, that brought good results in the past .
Thanks for the proposal Roman
73 Ignacio
Hello,
A feasible solution for the 14 Mhz Moxon is to put it Vertical, so that you can hang it by the shorter side spreaders.
It works nice with a minor gain reduction but it’s easier to setup, despite you need a good tall pole (spiderbeam 12m fiberglass mast, ie)
Good luck!
I’ll try and get some activity happening from Zone 29. 20 metres LP 07:00 -09:00 UTC best for us in Western Australia.. 17th suits me well at this stage.
John VK6NU
That’s also my observation, Ed. But as we move further into autumn in the northern hemisphere, LP will open later gradually.
Nevertheless, 6:30 z is just a suggestion. If people can go on the air earlier, there may be more opportunities for intercontinental S2S contacts.
73, Roman
Hi All,
Just to clear some confusion about possibility of S2S between EU and VK on 17th October.
VOACAP for today (1st Sept) looks like this.
As you can see chances of QSO on 20m at present 7UTC is 0%. However looking at cluster we can see several spots for VK posted on 20m band. Why is that? Is VOACAP wrong or propagation is a bit unusual than average. It goes beyond my pay grade. Maybe someone explains it.
15 should be operational and potentially 10 in the early hours of the day. Of course later afternoon and evening situation is drastically different and 20 is a band to go for.
Now lets fast forward to 17th October as proposed date for the event.
As you can see, the average band conditions for that day are substantially different with 10 being a band to go for. Considering the solar cycle I think its optimistic, but you never know,
At 6.00 UTC only 10 is and option at 7:00 15 starts to be available with 10 still being strong. At 8:00 15 is still very weak and 10 strong.
Here is a analysis for North Western Australia its a bit better on 15 and 10 but 20 is still very small chance.
As I said this is VOACAP and reality might be different. Propagation might be much better and all this is a total BS.
I’m in either way, and I want to try to make some contacts. If weather is good I will be at the summit if weather is poor I will chase from home.
I hope this clears some confusion about my earlier statement.
73 Marek
Comparing what VOACAP predicts with what I have been able to achieve over the last 3 months, VOACAP appears too critical (IMHO). I have made 20m LP SSB QRP contacts many times when VOACAP has said, at my power level and antenna, it should not be possible. It may be more accurate at 100 or 400W however when it gets down to QRP from a quiet location, my experience is that more is possible than VOACAP predicts.
Marek, that’s short path. For 20 m condx, change “chart” to long path.
Ahoi
Pom
Bet me too it!
I was running my MTR-5B from a small 3s lipo last week, so I think I would have been putting out around 4 watts. The QSO to VK1DA/P at 0611utc was easy peasy - could’ve been a regular EU S2S.
The LP propagation is there. VOACAP ignores long path unless you tell it other wise.
73, Colin
Hi Roman @DL3TU Thanks for getting this started. I’m in, as long as nothing else comes up. I might bring a bit more output power (FT891) and two different antennas. I’ve been planning to go to Schauinsland DM/BW-008.
Marek @SP9TKW Just be there
On that day, we can always switch to 15 and or 10 meters. Hope we hear each other in an S2S ![]()
73 Marcel DM3FAM
