Hello,
I am downloading the EG7GURU/P logs, and I have a problem: the download does not show the SOTA reference when the qso is S2S,
for example, I download the activity EA7/GR-123 and this is the result:
V2,EG7GURU/P,EA7/GR-123,30/03/2023,08:30,10MHz,CW,EA2TW,
V2,EG7GURU/P,EA7/GR-123,30/03/2023,08:33,10MHz,CW,F4WBN,
V2,EG7GURU/P,EA7/GR-123,30/03/2023,08:34,10MHz,CW,F8DGF,
V2,EG7GURU/P,EA7/GR-123,30/03/2023,08:34,10MHz,CW,EA2DT,
V2,EG7GURU/P,EA7/GR-123,30/03/2023,08:35,10MHz,CW,EG3GURU/P,
EG3GURU/P is qso S2S but it doesn’t show it.
I am doing something wrong?
TNX in advance
73 José
The activator log does not include the other station’s reference. You need the S2S or chaser log for that.
Hola Jose,
In Sotlas the S2S is show
73, Éric
If you choose to download via the Manage Uploads feature, this should include the S2S
TNX Andy,
but the problem is that I can’t download via manage uploads the logs of the other operators. No problem, I ask for every log.
TNX also Eric.
73 José
What exactly are you trying to do José? PM your requirements and I’ll see if I can get you the data you need.
Hi Andy,
I want a log with all the data from EA7GURU/P (from summit) and EA7GURU (from home), then I would upload them to LOTW & eQSL.
I can do it, but I was looking for an easier way.
73 José
PD. Now to work. ea7/gr-125 coming soon with my friends Alex y Elena EA4DOS-DOn
