If I can get the rotator sorted in time I will look for you.
Every HF operators starts off calling CQ and then stays on the same frequency. However, I donāt think any of the notes for HF bands use the same phrase as can be found in the UHF/VHF notes which says ācall CQā. I guess thatās the bit which needs clarification. Is the implication you call CQ then QSY? If not why use the phrase?
If I get a response from the RSGB Iāll post it on here.
AFAIC, I would no more call CQ and stay on 144.300 than I would on 145.500, but I will be very interested to see the official interpretation!
My recommendation is that you still alert for your preferred working frequency, say 144.250MHz and start there. If you can self-spot all the better. If you donāt get any response after a few CQS, then call on 144.300MHz where hopefully you will pick up a contact (not necessarily a chaser) and make the QSY to your preferred frequency. If you have to repeat this, then do so.
Although some may hold a different opinion, I recommend you use an antenna with some gain and, if you have the capability, as much power as possible. I use 25W output to a 5 element and it is a bad day at the office if I donāt work Don G0RQL in Devon from up in Scotland. Distances in the order of 600km are generally achievable.
VHF has the added complexity of antennas that have narrow beamwidths. It makes good sense to have a meeting point as you search for contacts.
Yes, yes, yes, once contact has been established. Itās what everyone doesā¦ regardless of any edict from whatever āauthorityā.
P.S. I am not RSGB-bashing hereā¦ after all, Iāve been a member since 1967
Gerald,
Thank you. It will be 10W into a 5 element Yagi set horizontally as thatās all Iāve got. If time permits I might swap it to vertical and try FM but if I can qualify the summits on SSB that will probably be enough. The forecast is cold!
It is what I personally consider to be the gold standard, but then 2m is not everyoneās bag. Obviously there will be summits where this will be nigh impossible, but I am often surprised by who will come on SSB. Many ops have multimodes monitoring the FM calling frequency in their shacks and they do take the time to flick a few switches and twiddle the big circular thing on the front and look for me down the lower part of the band. Many are using verticals, but from a summit I often work them cross-polarised. Putting the beam vertical and trying SSB is certainly worth a try before changing mode to FM.
See what happens on Saturday. If I manage to get out to a high spot to work you, then I will. The home QTH is not particularly good in your direction.
Thatās getting reasonably serious If itās doable you should!
Good luck
73 Paul G4MD/G6GGP
Please ignore the 27th, I have decided to postpone things until a later date. The weather forecast in the south west for this weekend, especially the Saturday, is a bit grim with gales and rain. The visit involved a campsite booking so I need to take the decision now to give the site reasonable warning we wonāt be coming.
If the forecast changes I might still go out but do it from Kit Hill G/DC-003 instead. Iāll post something on here if this looks like it might happen.
Itās ham radio. No matter what you do, someone will tell you that you are doing it wrong.
Yes and when they tell you over the air you are doing it wrong they wont normally give you their call sign. Well I know I donāt
I donāt know if you have operated from there before, but the mine chimney appears to be carrying a pager that blocks the receiver on some 2m rigs. Its operation is quite intermittent so you can work around it.
Thanks for that. Iāve operated on HF there a couple of times but not VHF.
