Planned Activation of G/LD-001 25 April 2023
Planning to activate Scafell around 1300 hrs UTC weather dependent.
Have you placed an alert?
A large number if chasers do not check on here for activation info.
An alert also tells us which bands and modes you intend to use and whether or not it’s worth trying to chase you.
If you don’t know how to alert, goto SOTAwatch (https://sotawatch.sota.org.uk) and click alert and fill in the form for your activation. Frequencies in MHz and time in UTC.
Note that Scafell G/LD-002 is a separate peak, and not valid for SOTA. I presume you mean Scafell Pike G/LD-001.
I echo what others have said about posting an alert rather than a note on the Reflector. However, far more powerful than either is to self-spot once you’re on summit.
