Just after you finished, Matt, I went up to 5.3985 and there was a very excited Italian station (if I read his call correctly!) working into G! Anyway, great contact, and if anything goes wrong with the 817, don’t mention the mod!
Brian
Brian
Hi Brian,
I fully support that.
I also remember doing so many years ago on 40m band calling bellow 7.100 on SSB for US stations and announcing that I was listening up somewhere higher than 7.1 or 7,2 I can’t recall exactly, where we (EA) were nor allowed to transmit. And it worked perfectly!
If I want to activate on 60m one of these days, I might need to do that same modif to my FT-817. I don’t even know whether it currently works on 60m. Neither I had heard about such modif before.
For the moment, I’d just like to chase some activators from home. My old TS-940S and my broadband folded dipole are ready for that.
Best 73 from Guru
Hi, Guru, this is where I found the instructions to wideband the FT817ND:
Its just a matter of opening and closing a row of jumpers by adding or removing small blobs of solder. It took longer to get at the row of jumpers than make the actual modification!
Brian
Hi Matt. Congratulations on your achievement! For me 60m was a big reward for getting the full licence. At the moment the bands are not very reliable, and I have found that 40 and 80 have not been functioning well for interG at times when 60 is OK (can be quite noisy). If I couldn’t use 60m I would be less keen to go out and try HF activations at the moment. Good luck. 73 John
