Only 3 UHF in WB but /AM from on high!
We were out on a small local summit G/WB-024 Aconbury Hill yesterday where VHF/UHF contacts are always a challenge as it is only 276m and the sides of the hill fort are heavily wooded. However it is only a very short walk and the area inside the main rampart is very pretty - especially when the bluebells are out (another week?)
I set up rather perilously on a high bit of rampart which overlooks Hereford
and I had a better view than usual as the leaves were only just coming out.and perhaps that influenced my VHF contacts as I had qualified within 10 minutes -an all time record. I was helped by a s2s with Gerald MW0WML who was out with friends on the Begwns GW/MW-025 which I was hoping for, but he hadn’t noticed our alert but recognised the voice. Perhaps this was the reason that he was not sufficiently equipped for our encounter as he had NO70CM WITH HIM. Fellow activators will know that this is the greatest SOTA crime in my rule book and I hold him personally responsible for the fact that, once again (as this also happened on our last activation on GW/NNW-059 Allt y Main near Welshpool) I was stuck with 3 70cm contacts and just couldn’t get that vital 4th. My grateful thanks to locals stalwarts G4WUH, M7SDO and M5RJC who did make contact and G8AOJ in Coleford, Forest of Dean who had a try but it didn’t happen. I have certainly found that VHF/UHF contacts are down since the various storms earlier in the year and it seems that the 70cm mast is the last to be reinstated (if at all).
After about 30 mins of calling I gave up, took down the mast and was coiling the guys with the VX7 on the ground (with just the stick aierial) when I heard on 145.500 a rather quiet call which seemed to end with ā€˜Aeronautical Mobile’ so I reacted quickly. I eyed the neatly packed mast, thought of the RH 770 but picked up the radio as it was and QSYd to 400 as instructed. There I found G0TPZ/AM calling so I hopefully answered… and a reply came back but I wasn’t sure it was to me as others must have heard the call. However my luck was in for this call as we had a 59/59 conversation as he flew in a Skyliner 2 seater above Hereford (ā€˜I can see the racecourse’) while heading for Cardiff at about 3,500’… I knew I had long ago had another /AM contact and Kev confirmed that we’d spoken to me before (unless there was yet another SOTA activator called ā€˜Viki’…) but not from the Hereford area. We gave a chance for anyone else to join in but no-one else appeared so I had time to walk across the fort, past the trig point,
and offer the contact to M0JLA Rod who was just starting to pack up his HF equipment. I don’t often see him that quick to stand up and take the radio but this was his first /AM contact. After a short chat Kev commented that that he was going into thin cloud and would have to go up to 4,000’ and continue on his way. It was a more cheerful pair of activators that returned to the car (HF hadn’t been too good either as 20m yielded only 3 contacts…). The only sadness is that we hadn’t been able to spot the plane but the tree cover is rather extensive - and we are not sure we would have seen him at that altitude. Thanks Kev. I look forward to the next encounter.
Viki
I can assure you helped me more! I was really struggling to drum up 2m FM contacts!
Sorry about the ā€œcrimeā€. My birthday is coming up… I will see if 70cm can go on the list!
Thanks both for the contacts!
Hi Viki, I have heard G0TPZ/AM twice over the last few days - Neil @M6NSV was in conversation with Kev at one point as well. I was tracking his flights - here’s his plane and previous flights: G-CCTR - Skyranger 912 [BMAA/HB/350] - Flightradar24.
On another note Aconbury Hill does look wonderful - I will take your advice not to visit on the weekend, or particularly over Easter, to avoid the crowds!
It’s a fabric covered kit plane, usually with a two-stroke engine. It’s advertised with a build time of weeks instead of years, which would account for a photo showing Russia using one as a remotely piloted bomber. Among the 45 aircraft types I’ve flown, none is kit built.
Elliott, K6EL
Like most microlights these days, the Skyranger comes with a Rotax 912 engine (4 stroke, 4 cyl), and you can either order it as a kit or have it factory built. You maybe might still find a 2 stroke in older models. It’s a good piece of kit that makes for (relatively) cheap flying.
FT-65E purchased at Blackpool… 70cm coming to a hill near you soon…
If you have a list of any you particularly want in GW/NW (and the northern bits of GW/MW) drop me a line.
