oe3chc aprs2sota
Hi all!
There are some aprs2sota spots after 04/25 12:00 UTC
from OE/NO-114 which are wrong - please ignore.
I hadn’t time to investigate the reason until now.
73 de Chris
Chris,log you in and delete your Spot!
Chris,Logge Dich einfach ein dann müsstest Du deinen Spot löschen können!
In reply to DK2RMP:
As it is from aprs2sota I can not edit/delete!
Tnx es 73 Chris
In reply to OE3CHC:
I’ve removed it for you.
In reply to DK2RMP:
Tnx es 73 Chris
ok tnx fr Info!
My APRS2SOTA system will only send a spot when it gets an APRS message containing adequate information from a registered callsign and will NOT re-spot within 10 minutes (to try and avoid Dupes).
My APRS2SOTA logs show that since 25 April it has received several such messages using the call OE3CHC that caused it to post spots on various frequencies - a log of those spots has been emailed to Chris (some additional logged information is available should it be required).
Stewart G0LGS
