New to the awards
if all the radio hams that do sota uploaded there log would i be able to find what my score on log search etc
In reply to M0HEM:
You can find your score from the database: View Results and the appropriate Roll of Honour. It doesn’t matter if other people don’t upload their logs as we work on a basis of trust…with penalties if that trust is betrayed.
In reply to G8ADD: cannot see myself if i was there i cud summit it to awards manager
In reply to M0HEM:
Hi John,
If you have not already done so you need to register your call sign with the database, follow the “Database” link at the top of the SOTAwatch main page.
You will then need to enter your chaser log into the database, once you have entered the contacts you have had with SOTA Activators into the database you will be able to see your chaser score.
Thanks & 73,
Mark G0VOF
In reply to M0HEM:
I can`t see you on the chaser database as either M0HEM or M3HEM, so unless you are recording your chases under a different callsign you have nil points.
In reply to G1INK: all calls are m0hem
In reply to M0HEM:
Hi
I think you are wondering if you might already qualify for an award based on previous contacts and whether that data can be extracted from the logs of others on the database?
It is quite possible that you do qualify, and it might technically be possible to reconstruct your log from information on the database entered by people that you have worked. However, that’s not how it works. As mentioned above you need to set up an account and start logging things yourself. If you have the details of previous qualifying contacts you could enter them retrospectively. If you don’t you will need to start anew.
I hope that helps?
73 Richard G3CWI
In reply to M0HEM:
activationdate,timeofday,summitcode,name,owncallsign,othercallsign,band,mode
10/24/2007 ,10:32,GW/MW-022,Aberedw Hill,GW4BVE/P,M0HEM,7MHZ,SSB
10/10/2010 ,10:05,ON/ON-010,Baraque Fraiture,ON7PX/P,M0HEM,7MHz,SSB
10/10/2010 ,10:54,G/NP-004,Whernside,G1INK/P,M0HEM,7MHz,SSB
10/11/2010 ,15:51,GW/MW-019,Gwastedyn Hill,GW4BVE/P,M0HEM,5MHz,SSB
10/17/2010 ,14:36,G/WB-017,Shobdon Hill,G3NYY/P,M0HEM,5MHz,SSB
11/2/2010 ,11:41,GW/MW-027,Moel y Golfa,MW0COP/P,M0HEM,7MHz,SSB
11/2/2010 ,12:08,G/SC-008,Win Green,G3RDQ/P,M0HEM,5MHz,SSB
3/11/2012 ,12:43,ON/ON-010,Baraque Fraiture,ON9CBQ/P,M0HEM,7MHz,SSB
5/6/2012 ,14:25,G/CE-003,Bredon Hill,GQ0IBE/P,MQ0HEM,7MHz,SSB
6/10/2012 ,14:53,G/LD-008,Blencathra - Hallsfell Top,GQ0OOO/P,MQ0HEM,7MHz,SSB
9/6/2012 ,12:06,GW/NW-071,Mynydd Bodafon,2W0WDS,MO0HEM,7MHz,SSB
2/3/2013 ,10:10,G/SC-008,Win Green,G4WSB/P,M0HEM,7MHz,SSB
4/30/2013 ,12:31,GW/NW-012,Cadair Berwyn,MW0IML/P,M0HEM,7MHz,SSB
4/30/2013 ,12:45,GW/MW-004,Pen y Garn,GW4VPX/P,M0HEM,7MHz,SSB
4/30/2013 ,18:08,GW/SW-032,Mynydd Allt-y-grug,MW6EWM/P,M0HEM,7MHz,SSB
5/14/2013 ,16:52,GM/SI-099,Sgorr nam Faoileann,GM4MD/P,M0HEM,7MHz,SSB
5/20/2013 ,18:59,GW/NW-073,Mynydd Rhyd Ddu,MW6GWR/P,M0HEM,7MHz,SSB
7/7/2013 ,15:49,G/NP-008,Great Whernside,GV0OOO/P,MV0HEM,7MHz,SSB
7/7/2013 ,16:00,GM/SS-132,Roan Fell,GM4MD/P,MV0HEM,7MHz,SSB
7/7/2013 ,16:09,DM/HE-568,Wolfschur,DL3SBA/P,MV0HEM,7MHz,SSB
8/24/2013 ,09:34,DM/NW-236,Grossendrescheid,DK9ES/P,M0HEM,7MHz,SSB
9/4/2013 ,09:37,GW/SW-009,Mynydd Troed,MW0IML/P,M0HEM,7MHz,SSB
9/4/2013 ,14:37,G/NP-004,Whernside,G1INK/P,M0HEM,7MHz,SSB
9/7/2013 ,11:45,ON/ON-016,Les Aisances,OT6V/P,M0HEM,7MHz,SSB
9/23/2013 ,11:25,GW/SW-031,Mynydd Uchaf,2W0RGE/P,M0HEM,7MHz,SSB
12/11/2013 ,13:50,G/LD-037,Little Mell Fell,G7KXZ/P,M0HEM,7MHz,SSB
Rod-back-own
That is very kind of you to take the time to help. Within that crusty surface there is a kind heart :wink:
Mike G6TUH
