Email from Ofcom FINAL DECISION ON VARIATION OF LICENCE(S)
Alongside the Final Decision we have published Guidance on what you should do to ensure compliance. We have also produced a simple EMF compliance flowchart which tells you whether or not you need to take action and, if you do, what action is needed.
Licensees will have the following time periods to make sure they have up-to-date records in place:
a) Until 18 November 2021 for any equipment which operates on frequencies at or above 110 MHz.
b) Until 18 May 2022 for any equipment which operates on frequencies above 10 MHz but below 110 MHz.
c) Until 18 November 2022 for any equipment which operates on frequencies at or below 10 MHz.
Will we need to Tape of areas, Have warning signs, take barriers? to keep the general public safe or simply use a rubber duck so we can be more mobile.
