After yesterday failed activation of Mt. Soratxipi EA2/NV-084 and once the problem of my rig not switching ON was found and corrected, I went there again today and activated that summit successfully. In this occasion, I drove about 2 Km on the mountain dirt road and parked at the point marked with a red arrow on the map below:
Since I knew the drive on the dirt road would give me a good amount of extra time, I prepared for a possible 2nd activation of the nearby Mt. Aitzarbil EA2/NV-179.
Another mountain dirt road started by the NA-4114 road and let me drive about 3.5Km up to the point marked with a red arrow on the map above, which is about 850m a.s.l.
From the parking spot, the hike included another lower summit on the way and was a bit over 200 vertical meters.
After parking the car, I started a steep hike through forest. See this picture taken with my parked car visible:
The ascent went through the forest and the track often wasn’t too obvious:
And the summit was finally reached:
There’s not much room for long wires at the summit, which is more or less clear but surrounded by forest:
I managed to erect my 7m fishing rod but the 14m long antenna wire couldn’t be fully extended as a sloper and I had to do a bit of zig-zag with the help of some branches. I didn’t take any pictures because I had no room enough for me to have the right angle.
The activation started on 30m CW, where I logged 14 QSOs, one of which S2S. Then I QSYed to 20m SSB, where I logged 9 QSOs. After a number of unresponded CQ calls, I went QRT because I wanted to descend the sometimes not very clear path through the forest well before the Sun went down.
I’ll be looking forward to copying you all again from a summit soon.
Guru
