Its almost done. Combining the joys of Motor cycling and having the radio as well.
Hoping to return to Kitt hill shortly once me MCP is sorted out as gotta break out bike fit the gear and make sure there are no teething problems prior to going hopefully at weekend WX depending.
Wil be using a 10m squid pole attached to the rear rack of the bike and anchored the old girl to the deck via stakes and ratchet straps. And run a 20/40m linked vertical end fed with CP wires on ground, Also have 80 and 160 LC.s as well this new version of me FW 2m Loop hoz for SSB of course. And me specials HB wooden box to carry certain radio parts as well the CP wires that can be easy wound into the box and pulled again photos laters.
Power Supply will be pair of slabs 12AH and a 7.6 AH LP4 battery and FT857D with MFJ939 AATU the grab and go kit. Plus fold away table and chair of course. Just gotta find something to clip to the grab and go radio gear so it forms a shield against bright sun thus being clip on if required. Plus the booth tooth gear sender from the radio and head phones.
Prob drop line 24hrs before going was planning Saturday but a wedding got in way DOH
Karl Currently 2Q0FEH till end of month then back to 2E0FEH.
Ps if ya want me normal call do ask no problem to oblige
