Mini Cycle Tour - 4 more in Galloway
I had started the year with plans to activate at least 20 new uniques in England, as part of a long term project to activate all English hills by human powered transport. However, I’ve gradually moved away from that idea to focus on the Scottish Southern Uplands, with a plan to activate the hills using human transport (although I allow use of the train/bus to get myself to the start of multi-day outings). Now that I’m done with G/LD, G/NP and G/SB, I just prefer cycling and walking around Southern Scotland than trips around Greater Manchester activating G/SP.
So I planned a mini cycle tour, just one night to tick off a few more hills near Dumfries. The idea was to explore an area of ground that I had only cycled through a couple of times before, bordered by the B729 (Dumfries to Moniave) and A712 (Dumfries to Dalry) roads. Both are roads I have cycled many, many times before as a part of longer cycle tours, but I have only once deviated into the triangle of land between them.
So On Saturday 26th September I found myself heading out of Dumfries on my touring cycle, with my first target being See Morris Hill (GM/SS-274), a small hill (240m) just outside Dumfries. See Morris Hill lies in the transition between the lowland farmland around Dumfries and the higher, more rugged country to the north and west. The hill has relatively gentle slopes, with fields, woodland and rough grazing on its lower ground
The weather was sunny, but really quite windy, and it was a bit of a push against the wind at times. The outskirts of Dumfries quickly changed to gentle hill country, it was really quite a pleasant area to cycle through. I soon found myself at the junction for the turnoff up See Morris Hill. A tarmac lane ran, sometimes steeply, up the hill, and I dug in on my lowest gear. The road was covered in fallen leaves in places, which is not idea for traction on a steep hill.
At this stage I was wondering just how high the tarmac would run for, I was delighted when it seemed to keep going all the way up to the top. I was less pleased when the road passed through a field of cows with calves near the summit. The cows seemed to be familiar with having passing vehicles, so were not too fussed by me. Nevertheless, I was pleased to cross a cattle grid exiting the field, at the boundary of the activation zone. I kept going a little further to get closer to the summit proper, but found much of it is fenced-in as part of a mobile phone mast. I then realised that this top-most field was occupied by a couple of bulls, who looked unhappy at the idea of me putting up an antenna. I went through a gate into a neighbouring field, at started my activation there.
This was unusual as a SOTA summit, allowing me to operate bicycle mobile using the half-wave mobile whip mounted to my bicycle. First contact was with M7AVT followed by GM3AIM and MM7EXK. Despite calling for a while, a didn’t get a fourth caller on 2m FM so moved to 40m CW.
I rushed to get the antenna up, taking lots of shortcuts that just led to long delays. Eventually, a poorly arranged antenna allowed me to start calling CQ on 40m CW using my QMX, I made a contact with DF1VTI and G0FVH. My antenna was very poorly erected, and the solar conditions were far from ideal, so I made no further QSOs.
Google Photos
Activating See Morris Hill
The decent was very speedy, and I was soon back on the road, heading to the village of Shawhead where I paused for lunch. I sat on a bench outside the village hall, munching on food from my panniers. I must have spent almost an hour here, before I set off again, still munching as I cycled.
I was not paying attention when I set off, and after a couple of miles realised I was heading in the wrong direction. I had to backtrack to Shawhead, to then leave by the correct road, heading northwards before turning into the pleasant Glen Kiln.
Just before reaching Glenkiln Reservoir, I headed up the single track road climbing to an elevation of 200m. I parked my cycle next to a footpath sign (an unusual feature in Scotland) and then headed up the hillside towards GM/SS-224 (Bennan).
The summit is marked by the monument to John Turner, who died in 1841 aged 60. Turner was a travelling craftsman who visited farms in the area, making spoons, forks and other objects from animal horn. According to local tradition, he chose his own burial site on Bennan and prepared his grave before his death. The story also says that, after local youths interfered with the grave, Turner made them carry his coffin up the hill when he eventually died.
At 398 meters, Bennan is an easy climb, but has some nice views of the surrounding uplands. It was interesting to look back to See Morris Hill, and also look ahead to my next planned hill.
Google Photos
Turner Monument
Google Photos
Activating on 40m CW
Google Photos
My “shack” is just as untidy in the field as it is at home
I called out on 2m FM at first at about 1445 BST, using the monument to shelter from the wind. GM4WHA called first, followed by GM7ANE and MI6LNP. Again, I didn’t manage the fourth contact.
I moved down too the fence-line and bungeed my pole to the fence to start activating on 40m CW. M0RWX was first, followed by ON4VT, G4CMZ and DF1VB. Conditions remained poor on 40m and so I was soon packing away and heading down the hill.
back on the cycle, I freewheeled down the hill and back to the reservoir heading to my next hill, Bishop Forest Hill (GM/SS-228). It was now late afternoon, and I was starting to think about where to camp. I needed a water source at some point, and it didn’t look like there were any streams on the way up my next hill.
The road climbed out of the Glen, following the Marglolly Burn with several spots that might have made a good campsite, especially near Cornlee Bridge. I eventually parked my bicycle at the junction with a track, near the summit of the road. and the headed off up the hill side towards the summit of Bishop Forest Hill.
Of the three hills this was the most enjoyable, feeling the most like hill walking. The going was fairly way at first, following a faint quadbike track. Near the first false summit the quad track disappeared, and I found myself wading through chest high grass and worrying about ticks. This was still a thoroughly enjoyable walk in the evening sunlight.
The summit had an open trig point - always a delight, and a huge cairn to allow me to shelter from the wind.
Nobody responded to my calls on 2m FM, so I quickly setup for 40m CW, making use of the trig point to support my pole. I sat with my back to the cairn, trying to get out of the wind. EA1AER was first to call, followed by G3RDW, IN3KLW and OE6HTD…and several other calls.
Google Photos
Summit of Bishop Forest Hill
Google Photos
Antenna and Radio Setup
I lingered for a bit, enjoying the views, and the general feeling of being outside. After packing up, I made way way back down the hill side, and seemed to choose a worse path than on the way up.
Back at the bicycle, I spent some time trying to decide whether to take water from the burn next to the road. I spent time looking at OS maps to work out where the burn came from (there was no habitation higher up). I have a Sawyer water filter and Chlorine Dioxide tablets, so the main concern is chemical contamination rather than bacteria.
Anyway, I decided to head along the road to a farmstead and see if I could water from there. Although there was clearly someone at home, they didn’t answer me, so I just took water from their outside tap, and filtered it later.
The only time I have been seriously ill from water when hiking/cycling is when I took water from an outside tap at a farmstead in the Cairngorms. I didn’t filter it; I spent the night being very, very unwell.
Now fully loaded with water, I headed back up the road, exploring potential camp options I had spotted on the way down. I eventually settled on a lovely spot, around 500m along a rough track, well out of view of the road, but with a great view down the valley. It was getting dark when I put up my tent. Given that I had set-off at about 0530BST, it had been a long day.
Google Photos
Camp Spot
The next day was due to be very wet, from about 0900hrs, so I set off at dawn, heading north to Bogrie hill. It was a lovely cycle ride, with plenty of typical Galloway countryside, and lots of Galloway cattle.
A tarmac road took me close to Shillingland homestead, where I parked my bicycle and headed up the hill. I was suffering from some quite bad stomach cramps, which I attribute to an Aldi protein bar that I had as part of my breakfast. This high protein stuff really doesn’t agree with me.
The trek up Bogrie hill was a bit messy at first, picking my way around bracken. But once on the hill proper, a quadbike track provided a guide around boggy bits an up tot he summit.
The trig point was open again, which was just as well as again II made 3 contacts on 2m FM (2E0ACE, G6LSO/M and MM9RAB), so 40m CW and my QMX allowed me to qualify.
Google Photos
Activating Bogrie
It was raining by the time I finished the activation at 0945BST, but there was a still a good view at times on the descent. The hill’s isolated position gives it good views across the surrounding uplands. To the west, the landscape extends towards Cairnsmore of Fleet and the Galloway hills, while Loch Urr and the hills around the upper Nith valley can be seen in other directions.
By the time I was back on my bike, the rain was torrential. I had planned to activate one further hill on my way home, GM/SS-285. I stopped at the junction for the path and got off my bike, but the stomach cramps were pretty bad – it was difficult to stand upright.
I stood around for a bit, hoping the cramps would pass, but that was not much fun in the torrential rain. I decided to leave the hill for another day, and headed back towards Dumfries and then home.
Good report.
GM/SS-285 was a good miss unless you have the time. I have been there twice and both times access was not as easy as you would expect for such a small hill.
I did wonder if that might be the case. It looked like I would need to skirt around the edge of some forestry. It sounds like I made a good decision to leave it to another time.
It was interesting to see your name as the most recent activator on some of the hills (now over three years ago). I am impressed by how many contacts you managed to get on VHF.
Excellent report Matt. All summits I enjoyed very much and doing Uniques it was a bitter-sweet day when the Dumfries group of summits were complete. I remember them well and also remember some of the contacts made, mainly on 2m SSB which was very much in vogue back then (2012-13)..
Unfortunately I was committed to family activities when you were up there and so missed the opportunity to work you on 40m CW. However, no doubt you will be going back for a few more delights in due course and I hope to work you then.
