…as I alluded to many posts back. Slant polarisation has a problem if widely adopted.
What is needed is a massively upscaled metronome movement. Take that to the summit, mount your pole to the movement and then have your antenna sweep back and forth covering all possibilities.
Simples.
My fibreglass pole / 2m-J-pole has been auto-slanting in the high winds recently with angles dependent on the wind gusts. Here’s an idea: if I captured the angles in real-time, sent that data via a back channel, the other op could motorize the slant of his antenna to synchronize with mine. Oh, but what about the back-channel antenna slant?
I see no reason why it should be widely adopted. For a home station it is much more sensible to have antennas available for both polarisations: two beams, a single crossed yagi or a horizontal beam plus a white stick, which is what I have. The only problem occurs if it is widely adopted for activating, and that is only likely to become a significant problem if there is a widespread renewal of interest in SSB - which at the moment seems unlikely no matter how desirable!
Now you ARE being silly… surely the best option is to mount a rotator on the pole to rotate the antenna boom at say 50 rpm and have the coax run through the boom to feed the driven element via a slip ring arrangement. ![]()
If only you could electronically vary the polarisation…
I’ve heard the “turnstile” antenna described as being a dipole rotating at the frequency of the signal being transmitted… mount one of those in the vertical plane it’d be going faster than any rotator could spin it ![]()
@M1BUU Colin, here’s your challenge for something to build on the summit for when you do your 2x Mountain Goat activation.
