I’m thinking of using Lora APRS but am starting from the point of no knowledge ( other than very minor) of what is needed for the system. The intention is to use the car to power the device and use a 1/4 wave as the antenna. Will the system auto boot as the car powers up or will I need to find a constant supply ? Also do any of you have any recommendations of good sites/ videos that will talk me through what is needed and how to set it up ? I have just gone through an introduction to DMR and whilst looking for information found many videos that either were poorly explained or just massively padded out.
I use a Heltec Wireless Tracker in my car. In the fuse box (under the steering wheel) I connected a power cable at ignition plus, inserted a step-down-converter 12v/5v and ran the cable to the back of the car where my tracker is. From there a short coax goes to a small 1/4-wave vertical on a magmount.
The tracker is powering on when I start the engine. I also inserted a small ON/OFF switch to the cable (it is within reach while driving) to be able to turn the tracker off at any time.
Those EByte E22-430M30S modules have up to 1W output (and cost around £6) and both Ricardo and Damian’s web-flashers support the same hardware configuration:
It’s powered from a 5V rail, so if your vehicle has a USB socket which comes on with the ignition you could use that. No display is needed as it lives in a corner of the boot.
