Ever wish you hadn’t mentioned something? I had to double-check the thread title, and the thread originator in this most tedious of discussions!
Back on topic then. It was Valentine’s Day, Thursday 14th February 2013, and after giving Marianne her Valentines card (she hasn’t given me one yet), I had a doctor’s appointment in town. After hearing the news that I have brain surgery to look forward to, I decided to take my daily exercise roadshow to Gun G/SP-013.
A significant flood on the road just short of the parking spot had to be driven through. I don’t normally risk these things and find another route, but just before me, a car with a much lower bottom than mine went through. So I did, and it was fine. Mike 2E0YYY’s car wasn’t there. I had seen his alert for this summit, so thought he would be along at some point.
The amount of lying water on the road suggested that the footpath to Gun summit would be rather waterlogged, and indeed it was. Right by the initial gate and stile, an ample stream of water was running down the path and into the heather at the side. It then appeared to go absolutely nowhere, even though there was plenty of lower ground. I presume there must have been something of a cavity underground at this point, and the water was getting saturated into a small area of ground, and draining underground. Geology lesson Brian?
The walk up to the summit was more a game of ‘avoid getting your feet wet’ than ever before. I set up the 20m groundplane a few feet beyond the trig point, and connected it to the HB1B, using the SO239 to BNC socket adaptor, which now lives with that transceiver. After setting up, I scanned the area for Mickey 2E0YYY, but still no sign.
The weather was cold and breezy, but dry despite the menacing grey cloud hanging overhead and as far as the snow-streaked Roaches, whose summit it engulfed. The first run on 14.011MHz CW attracted plenty of SOTA and WFF chasers, and I stayed ahead of the 1 QSO per minute rate, making 27 contacts in 20 minutes. Things did then slow down somewhat. And still no sign of Mickey.
At one natural break in proceedings, I listened in to EC2AG/1 activating EA1/BU-086 on 14.280MHz SSB. He was a 57 signal, but since the SSB is receive only on the HB1B, I couldn’t try to work him and this will go into the SWL log. And where was Mickey?
My original QRG of 14.011MHz had become less useful due to splatter from QRO stations nearby. I could use the IF filter knob on the HB1B to get rid of them, but I was also ridding myself of listening over a preferred frequency range, and possibly not giving my 5 watts the best opportunity to be heard widely. I did some running on 14.049MHz and 14.024MHz CW, before finally returning to 14.011MHz CW once it was clear again.
Glancing around from my sitting position, I noticed something in the air. It was a colourful kite, and I assumed this meant that Mickey had arrived! I knew from the alerts that Mike was planning on doing some 14MHz SSB, so I set about wrapping things up on 20m CW. By 1150 UTC I had cleared my QRG, after making 55 QSOs in 83 minutes. Quite sluggish really, all things considered. The HB1B was reading 10.3V, so time to bring it in for a recharge. I will do so more frequently in future to keep the power output up nearer to the nominal 5 watts, but I wanted to get an idea of its capacity. Answer? 371 QSOs in 8 activations. I can live with that!
I went over to say hello to Mike 2E0YYY/P, who was working on 40m SSB at that stage. He was pleased having worked Barry MW0IML/P on Arenig Fach GW/NW-027 summit-to-summit for one of the few remaining Welsh summits he had not yet chased S2S style. Two CQ calls on 2m FM from the handheld solicited precisely nowt, so I descended (hopped and shuffled around avoiding the bogs and the deep-ends of the puddles) and drove home for a sandwich.
Tom M1EYP
