As for bands above 20m why do people persist with very low
horizontal dipoles?
The linked dipole can be used in vertical position too. You can take out the 30/40 m bands and it becomes about 10 m high linked vertical dipole. Also some compromise or sloped operation is possible. Or you can make L-bends to the ends of the dipole for a shorter “vertical”. Tuning will probably shift a little though.
There seems to be an aversion to the use of tuners in SOTA! I use two of them: for the FT817 I have built a Z-match using a toroid, it has balanced/unbalanced switching and a switched in inductor for Top Band and it weighs just 360 grams with its patch lead. For the FT857 I have a parallel tuner for a W3EDP antenna, with a switchable series tuning capacitor to improve flexibility, its a bit more beefy than the Z-match at 600 grams but it will handle 100 watts!
For those who object to the weight, if 600 grams is going to break your back you need either a better rucsac or to lose some weight, and as for the reputed losses of a tuner - well, they are too small to be noticeable on the air!
So what is the advantage of the tuners to offset the added weight and the reputed losses? Well, whether you use a doublet, an OCF dipole, a random wire or a W3EDP, you don’t need to stir from your operating position to change bands - and the change is done in seconds. It’s all right getting up to lower the antenna and change links if you are on a nice grassy summit, but stumbling over rocks and boulders on a rocky summit is a different matter, why add to the inconvenience and risk hazards such as sprained ankles?
My entire LF antenna, feed, connectors, mount, endropes and a box to carry it all in only weighs 600g. With the vertical that becomes 850g to cover 60/40/30/20/17/15m. You’ve got 960g and nothing to actually radiate any signal yet!
In reply to G7MRV:
Dipole(30m)/coax,Radio,li-po,key,headphones,notepad,pencil,fishing rod,gps,maps,compass and the rucksack 2.4kg. It works and no contests or phone on 30m.
You can make a one band dipole and test it in 15 minutes.
So what, Andy? My thermos of hot tea weighs a lot more than the tuner, come to think of it, so does the pullover that I carry in winter!
It isn’t a competition to see who carries the least weight, there is no prize for the lightest station, it isn’t like the serious backpackers that actually cut a bit off the handle of their toothbrush to save a few grams, its just a matter of carrying the gear that you fancy using! Getting paranoid about eliminating weight says more about your state of fitness than it does about the capabilities of your station!
See now, if I am happy to carry my FT857, bigger tuner and a 13 Ah SLAB up a hill, I am certainly going to think of a climb carrying the FT817 and the Z-match as a light-weight stroll!
Oh yes, and my carry gives me 160, 80, 60, 40, 20, 17, 15, 12 and 10 - also 30 if I was into CW - and I can get from any one to any other of those bands without getting to my feet, I think that is worth 360 or 600 extra grams!
Well, had great weather today, so rebuilt the link dipole, fresh crimps. All absolutely spot on now. Labelled up and ready to go. Tested on-air on three bands (10m and 12m dead today), contacts all around Europe with 5w, including a SES that was about to go off air, when i heard him, but though the rig was on 17m, the antenna was on 40m! Jumped to swap links, worked him, then realised i hadnt pushed the mast back up!
Looking forward to Scotland next week now
Mods - I think we’re done on this thread now, please close at your convenience
