Found another video of EA5IW. I would say he is also in the top 10 for minimalism.
enjoy it haha
Julian
enjoy it haha
Julian
Thanks for posting this… his videos are great! 73.
Love everything about Ramon’s ‘concept radio’, right down to the military hard-stamped dog-tag label, with callsign, rig name (SW 20).
I haven’t had the chance yet to try my [re-discovered] MFJ short whips on another SOTA activation to find out whether or not the first (and only) time was a dream.
My village is next to a river estuary with wide sands (actually more a sand/mud mixture) at low tides, and it’s only a few 100m’s walk from my house. Background noise is S8-S9 on the lower HF bands in the shack but usually S0-S1 when out portable. The 1.3m-long whip and counterpoise worked well on hills but what about at sea level?
Initially I placed the far end of the 7m counterpoise in the salty estuary water. Surprisingly, I didn’t get a good SWR despite using the KX2’s brilliant internal ATU. So, I tried laying it just on the sand and got 1:1.0, which makes me wonder: I understand counterpoises work by capacitive coupling to ground. By making an electrical connection to the water, had I turned the CP into a simple earth/ground wire? And therefore less effective?
I heard G4XRV (300km from me) calling CQ on 30m with a 579 signal. We had a long QSO; he gave my 10W CW 549. I’m sure all that salty water below the antenna’s near-field helped a lot. And despite being at sea level it’s an excellent low angle take-off for over 180 degrees. So, the short whip & CP are doing the business here too.
I really wanted to try the 15m MFJ whip for the first time with the KX2. I was amazed by the Rx performance on 15m, even better than the 30m case. Almost all the CW contesters were 599+. But, by now I was very cold, being under-dressed and standing still in freezing conditions so I didn’t attempt to make contacts.
I’m keen now to try 15m and 30m on the next SOTA.
A quarter wavelength of wire will transform the infinite impedance at its open end to zero ohms at the rig so makes a good counterpoise. If the far end is grounded then the wire will do the converse and transform zero ohms to infinity at the rig and be a poor counterpoise. Perhaps a very short wire into the salt water would work.
But risk either the KX2 or me falling in!
Thanks for the explanation.
They’re not waterproof… a mild drizzle showed water seeping under the LCD perspex on mine. But you can kick them with a walking boot and they don’t dent. Did that 3 times on Ben Bowie GM/SS-251 when I kept developing cramp in my calf.
Funny you should say that Andy because I noticed a long line of condensation under the KX2 LCD perspex after that 30m QSO.
You too, eh! I’ve just bought a Helinox Chair Zero to get my backside off the ground and my legs sloping, which I hope will fix that problem. It’s very comfortable even with my current lower-back pain.
