I originally planned to activate ten summits, but I changed my route due to the weather forecasts I received along the way. Instead, I decided to hike along the mountain ridge covering LA/OL-052 Digerronden, LA/OL-049 Midtronden, and LA/HM-002 Høgronden.
While on Høgronden, I encountered snowfall and received a storm warning on my Garmin, so I had to make a quick decision about which side of the mountain to descend and which summits to activate the following day.
None of the streams or lakes marked on the map seemed to exist anymore. During all the hours I spent up in the mountains, I couldn’t find water anywhere, and I was starting to run low. I did find snow in several places, so I had the option of melting snow for drinking water. I also met several other hikers who asked if I had come across any water in the mountains.
Feeling pretty fed up and exhausted, I decided to descend on the eastern side, where I knew there was water in a small river or large stream. This would also put me closer to my car in case the storm warning turned into something serious. I had also spotted a small pond that I planned to visit on my way down.
During the descent, I noticed two large, furry animals lying down in the distance. I decided to keep well away from them to avoid disturbing them, since, after all, I’m just a visitor in their territory. At first, I thought they were wild reindeer, but after speaking with someone knowledgeable about the local wildlife, I realized they were most likely musk oxen. Probably a good thing I didn’t try to share their water with two musk oxen!
Once I had descended from the mountain, I set up camp on relatively flat ground about one kilometer from the mountain, where I found a stream flowing from the pond.
The tent I used was a Helsport Superlight SC2, weighing around 1.5 kg. For dinner, I prepared two portions of Real Turmat Bolognese. I slept on a Nemu three-season sleeping pad with a foam pad underneath and used a Helsport Alta Pro sleeping bag. I believe the temperature dropped to around 2–3°C during the night, but I had no issues staying warm in my sleeping bag.
The next morning was spent packing up and making a new plan. Since LA/HM-080 Sandomshøe and LA/HM-012 Storelgvasshøe weren’t too far away, I decided to activate those two summits. What made it even more special was that neither of them had ever been activated before!
After completing those activations, I hiked back to Øvre Dørålsæter, where I checked in with my tent and spent another night. I really should have completed the first-ever activation of NO-2840 Dørålen Landscape Protected Area from my tent, but I guess I should be happy with everything I had accomplished so far.
On the third day, I activated LA/HM-084 Veslkringla and LA/OL-362 Trabelifjellet on my way home.
I brought my Garmin GPSMAP 67i and had activated an inReach subscription so I could communicate with my family back home and spot myself. Self-spotting via inReach worked incredibly well and was surprisingly fast. Even though I had 5G coverage, it was still fun to test the inReach system. I received a notification from HamAlert confirming that I had been successfully spotted within 30 seconds of sending the message via satellite.
For radio equipment, I brought my beloved Yaesu FT-891, which I operated at 40 watts to complete the required four QSOs in record time. I used a 5-meter telescopic fishing pole from Biltema as an antenna mast, along with a homemade antenna winder and a 49:1 UNUN connected to a 10-meter wire (a 20-meter EFHW antenna).
Since my route ended up being considerably shorter than originally planned, I decided to go all out and work through the pileups that developed on the summits.
On one of the summits, HF conditions were quite poor, and I had to increase my output power to 100 watts to make enough QSOs.
I self-spotted on both POTA and SOTA to ensure I could get enough QSOs for the SOTA activations. I uploaded all QSOs to POTA grouped by day, while the SOTA logs were uploaded separately for each summit, to make sure everything was logged correctly in both programs.
This explains why there are several hours between some of the QSOs in my POTA activation logs from Rondane.
I also brought a 40-watt solar panel, but since I hadn’t used nearly as much power as expected and my battery voltage remained high, I never needed to use it.
All charging of my phone and VHF radio was done using the same LiFePO4 battery that powered my HF rig. I only brought one 12 Ah battery, which, in my opinion, provides quite a lot of power!
As a summary, I would definitely bring the same rig again if I’m going to do a SSB activiation again. I wont bring the solar though, because I had plenty of power left in the battery when I came back to the camp.
