Horizontal or Vertical?
It’s perhaps strange that there is little empirical data to allow activators to make an informed decision about which polarisation might perform best over different paths in different situations from a hilltop. Tom M1EYP and I decided a while back to make use of the RBN to compare antennas. Today we made a start.
We set up two antenna systems on The Cloud SP-015 and spent nearly two hours making test transmissions every 5 minutes. The antennas were a dipole at 6m AGL and an elevated vertical (top at 7m agl), both for 20m. They were about 150m apart.
To remove some variables we set our keying speeds and message formats to be the same and called at the same time. We both used 5 watts from FT-817s. We called 10KHz apart and swapped frequencies half way through.
Results and analysis to follow.
73 Richard G3CWI
In reply to G3CWI:
Ooh, something techy. Excellent!
Was the dipole in inverted-V configuration or where the ends supported so the element was really horizontal?
Inv-V.
Photos:
The horiz versus vertical performance may depend on steepness at the summit operating position. Operating over a sheer cliff may yield different results than with a 5% gentle downgrade from the summit.
73, Barry N1EU
Hello,
"…Ooh, something techy. Excellent! "
I have two receivers on the Flex 5KA. If I sync both and have one receiver into my vertical (left ear) and the second receiver plugged into a hexbeam (right ear on headphones) = QSB is rapid variations of polarity. If I then phase the two antenna using ESC then the QSB is reduced. Not ‘technical’ I know but it is real time in terms of listening to two polarisations at the same time. Leaving a time gap allows too much time ~ propagation variation.
Mike G6TUH
In reply to N1EU:
It may, it may not. But does it? That is the question!
In reply to G6TUH:
Leaving a time gap
…which is why the experiment was repeated numerous times. GCSE science!
In reply to G3CWI:
I’ll have what ever Tom was using.
Consistently stronger, actually made it across the pond with ease, and 17db up on you at OH6BG!
We need to know who was using what???
In reply to G4ISJ:
…you need to wait for some proper analysis!
In reply to G3CWI:
But RBN has already declared the winner :slight_smile:
In reply to G3CWI:
"…which is why the experiment was repeated numerous times. GCSE science! "
You miss the point Richard.
Mike G6TUH.
M.Sc. (awarded 1986) 8)))!
In reply to M1EYP:
Well comparing the data properly is the way to go. I have no idea what Pete’s graph actually shows and the real analysis needs to be over specific paths. It also needs to take into account the SD of the results to show the error ranges - but surely a mathematician realises that? :slight_smile:
73 Richard G3CWI
Indeed, hence why I will do it. Just struggling to summon up the energy and motivation to do so at present. Something happened between the activation and now to put me in a heightened state of relaxation, not sure what…
Something to do with a CRT I suspect.
Tom M1EYP
In reply to M1EYP:
I drive home, call in the shops to get some olives for my martini and milk for everyone else and find a zillion posts!
Knowing the people involved, there’ll be twist in the tale, so I’ll wait for the final analysis.
If everyone else is putting milk in their martini you haven’t trained them properly.
No matter what the analysis comes up with it will only be a snapshot, conditions vary immensely and at the same time on another day the results may be completely different, so it will be interesting but inconclusive. I’ll be incommunicado in LD for five days from tomorrow but I look forward to reading the omnibus edition when I get back…
In reply to G8ADD:
perly.
inconclusive.
All true. Tomorrow I will run another series of tests. They will be focused on seeing how reliable the RBN data actually is. I will carry out the test at two arbitrary power levels (the actual levels don’t matter much). What will be carefully controlled will be the difference between the levels. It will be interesting to see how the RBN reports the test.
73 Richard G3CWI
Short report of a similar experiment, not with complete statistics but mixed from RBN-figures, A-B-reports on air and receiving impressions.
20m-GP and 20m-dipole (fed @ 8m), not straight but not 90deg V-shaped. Antennas at a point on the hill where three directions offered three different contours: One direction very steep slope, one direction very gentle slope and one direction flat.
In the “steep slope direction” the dipole won with several S-units or two digit dB differences in RBN (be it more or less than 1000km).
In the “gentle slope direction” both antennas more or less the same with two A-B-tests on air giving some confidence in the results.
In the “flat direction” the GP won with more than one S-unit, but only three receiving impressions on the S-meter.
Of course more testing needed but at least no complete reversal of the gut feeling assumptions about those antennas types and their favourite slopes - so far :wink:
P.S.: Unscientific definition of steep and gentle: Steep is when you can not run down for some steps without falling :wink:
73, Chris
In reply to G3CWI:
When you have some results comparing horizontal and vertical antennas can I ask if you will be hauling up several tens of feet of aluminium scaffold pole and some CB twiggery to see how that performs in comparison?
Maybe you could do a comparison of signal to weight ratio for this and other antennas?
:wink:
In reply to DL8MBS:
I like Chris’ conclusions. I fear my attention span isn’t long enough to follow the plot of the Anglo antenna test.
73, Barry N1EU
