Ok don’t laugh, where do I call on 2 metre fm voice. Tried yesterday after cw with no success. Only used the mike a few times in 25 years and I find it as hard as others find cw . I looked on the RSGB web site but still not sure and Id like to give a few points on fm.
Generally from my experience it is best to call on 145.500 MHz to establish contact then move away to another quiet simplex channel. I’m sure the other party to the QSO could guide you to a suitable frequency if you are not too sure.
However, in the Edinburgh area FM is known as “feeble mode” and you would call on 145.800MHz AM irrespective of any bandplans (or satellites in range)!
However, in the Edinburgh area FM is known as "feeble mode"
Aha, so that’s how some of those well hidden SS summits are qualified so easily Andy. I must remember that when I’m next up there. Horizontal or vertical polarisation and are they likely to speak to a sassenach?
Hmmm, seems I’ll have to rub my FT-243 crystal with a pencil to move it down to 145.795MHz. That should keep me “legal” and confound both groups! Better still, maybe I’ll use DSB and that will ensure they’ll all be off down the pub, one lot unhappy that there’s an awful racket on “their” frequency and the other lot pleased that an indecipherable noise has jammed their opponents!
I’m sure you know, but here goes - History Lesson for the younger generation:
The polarisation for AM used to be horizontal polarisation as the mode was the predecessor of SSB on 2m. I remember working into OH on the mode and later the change over to SSB with the advent of the ubiquitous Liner 2. The calling frequency was on 145.410MHz, if I remember correctly. I used to call SSB stations with my AM rig netted on, often to be told that my carrier suppression had gone haywire. Eventually I persuaded the XYL to let me purchase a Trio TR7010 in 1976 which is still in use today.
Vertical polarisation came in with FM (which quickly became the preferred mode for mobile), largely because the antennae were simpler to mount on the vehicle and didn’t look like something from Mars.
In the case of the Edinburgh AM group, I would imagine that being a local group where signals will be strong between stations, simplicity will be the order of the day and verticals will be used. I could be wrong as it begs the question, where have all those halos gone? Come to that, where have all those Liner 2’s gone?
I don’t know about Liner-2s, Gerald, but a couple of years ago there was a Liner-430 at a local rally going for £30 - a bargain if ever I saw one, but someone else snapped it up!
I remember asking Tom, G3BA why 145.41 was the calling frequency for SSB and he said it was a palindrome and therefore easy to remember!
Well, since AM is likely to be a localised “speciality”, I would expect the answer for any group to be much along the lines that I surmised for the Edinburgh group. Verticals double for FM use, are easier to obtain and are more aesthetically low profile than a halo or similar horizontally polarised antenna.
If I get up into the SS’s this May, I’ll give it a go and let you know the outcome.
The Liner 430 - the biggest regret of my amateur radio life is that I sold mine. I modified it and put a Gasfet in the front end. It was a great rig, nothing at all like the Liner 2.
